Old 07-11-2021, 09:13 PM
DC-Choppah's Avatar
DC-Choppah DC-Choppah is offline
Default Re: Please help with 'Cannot initialize device...' when hitting play
Restarting does not fix.
The ONLY thing that fixes this is to Create a new blank session at the desired sample rate in ProTools, close it and then fire up the desired session. That always works.
The Tascam appears to not do any initialization itself. It needs what ever happens in Protools when you create a new session to initialize the device. Protools is NOT the problem, the problem is the Tascam.
I can power the Tascam off, power off the PC and then boot up the PC. Then turn on the Tascam. At this point we would think the Tascam has been initialized. But negative. The Tascam says it is set to 41.4 KHz. I fire up a session in Protools at 44.1 KHz and Protools says that it cannot initialize the audio driver.
I create a new session in PT and close it, then fire up the real session and it plays fine. The sample rate is a red herring. The problem is that the Tascam can't be initialized, even after powering down.
Changing sample rate requires a re-initialization, but the unit doesn't do it by itself, even after powering down.
So whatever PT does differently during a 'create new session' vs an 'open session' initializes the Tascam. The Tascam does not appear to initialize itself even if you shut it off and turn it back on?!? It is in the same 'unable to initialize' state.
DC-Choppah's Project Studio:
ASUS PRIME Z390-A / Intel i7 rackmount PC
Windows 10 home 64 bit
Pro-Tools 11.3.1
AIR Instrument Expansion Pack v2
WAVES Platinum plugin bundle
Tascam US-16x08 Interface
100% Analog real time monitoring 16x4
Yamaha 16 channel MG16XU Analog Monitor Mixer
Yamaha MX-88 / Novation XiO keyboards
Mackie 4-channel headphone amp
Adam A8X monitors
Blue / Shure, etc. microphones
Estonia 6' 8" Parlor Grand Piano
Yamaha Studio Drum kit
https://www.dc-choppah.com/
Old 07-11-2021, 10:12 PM
unkJE's Avatar
unkJE unkJE is offline
Happy you've got a Workaround!
Wonder if you've tried this sequence:
(1) Change the USB port
(2) Reinstall the Tascam Driver - complete installation of the driver on the computer before connecting the unit to it with the USB cable
(3) Restart computer
(4) Connect and start Tascam
(5) Set Buffer Size
(6) Restart computer
(7) Check Tascam Buffer Size is what you selected
(8) Launch Pro Tools – hold down “N” while launching will open the Playback Engine – adjust settings if necessary
(PS - don't worry about my quick log-outs - when using my wife's computer, I like to "clear the deck" quickly - then check the DUC on my phone ...)
Pro Tools 2021.6 & 12.5.1 HD - Studio One 5.3 Pro - Win10 64 Pro – Lenovo W520 ThinkPads (Type 4276-37U) & 433830U Docks – SSDs Samsung 860 Evo & 2 T5s - Mbox 3 Pro - Axiom Pro 49 - AIR Mini 32
Initialize MC Transport device Raynaldo Martine Artist Series 6 06-24-2020 03:00 PM
Exclusive Control of Audio Device or Cannot Initialize Device Alexlimbert Pro Tools 12 4 10-22-2017 04:41 AM
Pro tools 11 cannot initialize audio device serstickman Windows 19 09-29-2014 08:32 PM
Cannot initialize this playback device firewired Pro Tools M-Powered (Mac) 2 01-15-2014 09:33 AM
hitting play does nothing CCash Pro Tools TDM Systems (Mac) 6 07-19-2005 09:23 PM
