Old 12-21-2009, 05:20 PM
sungwoon1130 sungwoon1130 is offline
Default Mbox2 with 8.0.4 windows 7 driver problem
i installed pt update 8.3 then uninstalled the audio driver, restart the computer and installed 8.0.4 audio driver for windows 7 x64.
it detects as Degidesign Mbox2 Analog 1/2 on sound device.
But sounds are all scratchy and destorded. Any other DAW Sonar, Cubase is the same thing.
Need Support!
Old 12-22-2009, 09:30 AM
lowlevelowls lowlevelowls is offline
Default Re: Mbox2 with 8.0.4 windows 7 driver problem
Originally Posted by Benoni View Post
This been covered a few times already, try switching back to the 8.0.3 driver and see if that helps.
So do you just uninstall the 8.0.4 audio driver and then it defaults back to the 8.0.3 drivers? Or do you have to do anything else?
Old 12-22-2009, 10:09 AM
mykhal c's Avatar
mykhal c mykhal c is offline
uninstall 8.0.4 drivers and run a repair on 8.0.3 to re-install.
bassist...deep pocketz anyone???!!!
The Basschakra Lucid Soul Trip
i7 Builds - Specs and Results
HDNative | Omni | i7-3930K OC'd 4.0GHZ |
ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff
Old 12-22-2009, 10:31 AM
ok, i've repaired back to 8.0.3. now in DAWs it detects Mbox2 as a sound device. However, doesnt regconizes as windows sound device. Hope they get it to fixed asap.
Old 06-19-2010, 06:02 AM
ScottEOsborn ScottEOsborn is offline
Question Re: Mbox2 with 8.0.4 windows 7 driver problem
> installed pt update 8.3...
> it detects...
> But sounds are all scratchy and [distorted].
Haven't updated to 8.0.4 drivers, but am seeing the exact same thing with 8.0.3 - Win 7 x64 + 8.0.3 drivers = scratchy, distorted sound (from any DAW or audio playback device).
Help?
Thanks,
Scott Osborn
Old 12-30-2010, 09:48 PM
still avid didn't solve this problem!!
Please Fix this!!
Windows 7 mbox2 PTLE problem trazom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 02-09-2011 05:34 AM
Attempting to install 8.0.4b audio driver for Windows 7 MBox2 j4callen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-27-2010 05:46 PM
Mbox2 Midi driver problem Qusic MIDI 0 02-24-2008 06:21 PM
Windows Problem With Midi Driver alice_in_wire MIDI 0 12-02-2006 04:36 AM
Mbox2 not responding/problem installing the driver skribble 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-17-2006 08:27 AM
