Avid Application Manager causing major internet issues OS X!!
Hey guys
I always disable the Avid Application Manager but recently after installing 12.6.1 I had not gotten around to disabling it again and was having terrible internet speeds to my laptop, despite a very strong Wifi connection. I could not for the life of me figure it out until testing back and forth with my wifes laptop and mine and hers was performing perfectly did I realize the biggest difference was hers was not running any Avid software and did not have Avid Application Manager running. So I quit Avid Application Manager on my laptop and voila, internet speed is back to normal, I repeated testing through various reboots etc. and every time it comes back to the Application Manager disrupting my internet connection. Here is my normal internet connection speed: Here is the speed with Application Manager running: FYI this is not while the application is 'Syncing' its sitting idle The specs on my laptop below: 2015 15inch MacBook Pro macOS 10.12.1 Pro Tools HD 12.6.1 I dont how this could even happen and I am going to test further on my end but if you havent already please disable Avid Application Manager ASAP. |
Re: Avid Application Manager causing major internet issues OS X!!
I've had the same slow internet experience, even Apple TV will not work unless that app is uninstalled
I am fortunately not having these issues.
As a test, I started an internet speed test while Application Manager was running and vise versa. Both times the speed test was fine.
Retro 176 (pair), Pultec EQP-1A (pair), Germanium Comps (pair), BAE 10DC (pair), Distressor (pair), Manley Vari-Mu, Sta-Level, Zener, SSL Fusion, SSL FX G384, API 2500, LA2A, 1176, Bricasti, Massive Passive, Anamod ATS-1, Eventide H3500, TC 2290, Yamaha D5000, PCM92, PCM70... Amps, Amps & More Amps. |
Same here on a MacBook Pro. Finally figured this out. That is crazy.
Is there anyone who can open a support case with Avid?
Would be great to see this one logged as a bug, because they seem to be deploying a number of bug fixes for the app manager lately.
Pro Tools 2018.1 (Non-HD) | macOS High Sierra | 2.6 GHz Intel Core i7 | 8GB RAM | 7200rpm SATA Drive | iLok Cloud | Line6 POD UX2 | 256 Sample Buffer | 1 GB Cache |
if you remove AAM from Launch Agents Folder do you still have these issues ??? so if you wanted to use it you would launch it manually ..
MacHD / Library / Launch Agnets Folder .. remove the AAM file
Same Here. Running High Sierra on a Brand New MacBook Pro 2017 Touch Bar.
Same Wifi Drop. The Wifi come back each time I quit the Avid Application Manager!! |
I have the app running on both My Studio Mac and Main PC with only a - 2mb/s slowdown on the upload and this could be coming from one of my NAS doing some external Backup
you can look one post above yours and see what you can do with it !!! do you still see the same issues if it does not launch ?? if so, uninstall it .. avid gives you an uninstaller ..
Application Manager causing ghost image pop-ups and cpu spikes | gitrdan | Pro Tools 12 | 2 | 10-16-2016 09:51 AM |
Avid Application Manager app causing clicks/pops in audio system | Jperkins | Pro Tools 12 | 7 | 07-17-2016 07:58 AM |
Digidesign Databases Causing MAJOR Issues | enelson28 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 10-04-2011 08:10 PM |
