Old 07-03-2006, 10:19 AM
c-post c-post is online now
Default how to change DAE buffer??
In the reference guide it says "DAE is inside the DAE folder within your system folder". However when I open my system folder, there is nothing called DAE in there. The only thing called DAE in my drive is a DAE Prefs folder, and that appears empty. Is part of my brain missing, or did somebody leave something out of this?
Also, how can I up the amount of memory available to PT? Have things changed in OSX? If I "control I" the protools ap, I see there is a Memory tab in the Protools 6.4.1 Info window, however I can't click on the memory and change it from its default 52megs of memory. Why not?? In OS9 I was able to up PT/DAE memory to 200 megs, 600 megs, whatever.
I mention these items only because with a new install of 6.4.1 I am having performance problems of one sort or another.
sincerely in sync
c-post
"TISH! You spoke PROTOOLS! Speak some more protools, Tish... disk allocation, degree of thinning, timeline insertion...ANYTHING!"
Old 07-03-2006, 11:07 AM
LeGato LeGato is offline
Default Re: how to change DAE buffer??
go to "setups window", select "playback engine setup" and it's down in the left corner.
Not sure why the memory to app setting is set at 50000 although I've never had to adjust that because it seems you only need to use so much memory for running the PT app in OSX ( I could be wrong though ) , the rest of the CPU usage usually goes to using RTAS plugs or other soft synths which can be set in the "CPU usuage limit" in the same "playback engine setup" window.
Hope this helps,
RS
Supreme Beings of Leisure
album coming soon
Old 07-04-2006, 02:35 AM
usd usd is offline
c-post
jep, things have changed in osx! you don´t have to allocate a specific amount of ram to pt anymore...
Old 07-05-2006, 12:10 PM
Seeee Seeee is offline
hence the whole problem with OSX.
Old 07-05-2006, 07:05 PM
Chief Technician's Avatar
Can you be more specific? That's too vague to understand why you typed it.
c-post, how much RAM do you have in your system? We ran several MIX systems on v6.4.1cs4 with 1.25GB of RAM. Can you elaborate on your performance issues?
Old 07-05-2006, 07:49 PM
RobMacki RobMacki is offline
Memory is dynamically allocated in OSX. Hence the benefits of OSX.
PT loves the RAM in OSX. The more the better. I had 1.5GB on OS10.3.8 with PT6.9.1 for over a year and it was the most stable system for me in over 10 years.
Now I'm on PT7 w/ 3.5GB and I've got my fingers crossed.
Cant change buffer size shea Pro Tools 11 0 01-16-2014 11:38 AM
ProTools 8 Won't Startup, Can't change sample rate, Can't change h/w buffer size! Nickford Windows 0 05-26-2013 11:20 AM
Buffer won't change kivaz Pro Tools M-Powered (Win) 1 09-01-2010 11:35 AM
8.0.4 buffer change grief scottedog 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-12-2010 12:23 PM
Can't change H/W Buffer Size DestinysEnd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-07-2001 12:20 AM
