Old 10-23-2016, 07:46 PM
dr_daw's Avatar
dr_daw dr_daw is offline
Default Sierra test drive
Hey all,
Procrastinating on writing lyrics, so I thought I'd try Sierra on another partition. So far everything is working, except I can't seem to get past the 'security preferences' issue with Slate trigger.
Any of my other third party plugins; I was able to go in and allow them to install. But for whatever reason the Slate one is giving me grief. Any tips? I have tried re-downloading the installer, tried going to system prefs and allowing it in the security area, tried putting the installer in the applications folder each give me the same error. Something to the effect of 'Not an authorized developer from the AppStore....'.
I know Sierra's not qualified so save your breath; I'm only doing this as a test to see how things are running. So far aside from this everything runs just as it does on my Yosemite rig; but I haven't done any tracking to truly test.
FBR recording - https://www.facebook.com/fromthebase...cordsrecording
@FBRrecording - Instagram
Rig
MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2019.5, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, CAPI 312's, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors
Old 10-23-2016, 08:39 PM
Buccanears's Avatar
Buccanears Buccanears is offline
Default Re: Sierra test drive
Try this Dr Daw?
http://osxdaily.com/2016/09/27/allow...os-gatekeeper/
Q "where are your buccanears?"
A "on your buccanhead!"
IMDB
Old 10-23-2016, 08:43 PM
dr_daw's Avatar
Brilliant that would likely work. What I ended up doing was booting on my Yosemite rig and installing it on the sierra partition from there.
So far everything runs just as stable on Yosemite with 12.6. But I don't really use VIs, but I have the exact same system usage on both rigs.
Rig
Old 10-23-2016, 09:37 PM
PMF Media PMF Media is offline
You should just be able to right click on the installer and open it that way.
Old 10-24-2016, 06:59 AM
john1192 john1192 is offline
Originally Posted by dr_daw View Post
Hey all,
System Preferences / Security / General / Allow Apps downloaded from anywhere .. reset to Mac app store and identified when finished ..
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 10-24-2016, 04:07 PM
Um, that's the whole point of the OP's post, the option no longer exists in Sierra without a Terminal command line "adjustment"
Old 10-24-2016, 04:31 PM
dr_daw's Avatar
Exactly! Now I'm having an issue with Pro|control and like a dummy I didn't back up my iPad. So I hope it's not broken on my working rig!
Rig
Old 10-24-2016, 05:42 PM
DetroitT's Avatar
DetroitT DetroitT is offline
? PT | Control ?
Try Eucon updates 3.5 host and app
Old 10-24-2016, 06:17 PM
dr_daw's Avatar
Tried the newest eucon and ptc so far the faders don't show up. Works on 10.10.5 w/pt 12.6. Seems to lag pt boot on sierra as well. Might delete it to continue to test pt's on sierra
Rig
USB 3.0 for Audio Drive - Test Results Rob Ruce macOS 3 09-09-2012 01:32 PM
Test Drive tonight lwilliam Virtual Instruments 3 10-19-2007 10:45 AM
M-Powered Test Drive Questions ytrewq Pro Tools M-Powered (Win) 5 06-23-2005 01:50 PM
iMac G5 test drive azure sky 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-15-2004 12:11 PM
Test Drive - London? emptybe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-14-2003 02:45 AM
