midiman midisport 8x8 anyone?
anyone using this?
Re: midiman midisport 8x8 anyone?
I've been using it for almost a year now, and it works great with 001. The reason I purchased it over other Midi patchbays is because of the serial port connection...I don't use the USB or the SMPTE connections. I have 4 devices attached at this time...2 synths, drum module and MotorMix...with no noticable latency. It comes with software to manipulate the I/O as desired, and can be controlled via the front panel. It can be used as a standalone patchbay as well. The only desire I would like to see is to be able to change the names of the I/O within Pro Tools to read what is actually attached instead of just noting "MidiMan MidiSport In 1" etc..
same story here.. using it serial with usb disabled for more irq's.... never had any problem with it bar forgetting to power it on and having to restart PT to prevent MIDI glitches...
Hmm I think you can relabel i/o in PTLE. Might be just audio i/o though.. memory is sketchy.... |
thanks guys. that's one of the things i wanted to know , the serial port vs. usb connection idiom(great word, huh?!)
I've been using it for over 18 months, but I can only get it to work over USB for some reason. I'd like to run it over serial because I encountered loads of Pro Tools LE midi errors with USB and PTLE 5.1.1, so I had to uninstall and reinstall 5.1, where I encounter no problems. I'm just a bit concerned that future upgrades of PTLE may cause the same problem. Anyone else encounter this. I think the errors were 6042 or 6024. I used the drivers from the CD that came with. Cheers, Simon. |
damn, just realized that the g4's dont come with a serial connection, so if i want to use it i have to buy a serial card
midiman midisport 2x2 | dw drummer | Pro Tools M-Powered (Win) | 3 | 01-01-2006 05:32 AM |
Midiman Midisport 4x4 and Digi 001 PLEASE HELP!! | jessecobra | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-03-2003 07:50 PM |
midiman midisport 8x8 anyone? | nodoze123 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 04-24-2002 11:17 AM |
Anyone using Midiman Midisport 4 X 4?? | yavuzj | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-23-2001 06:57 PM |
001 and MIDIMAN Midisport 2x2 | jeronimo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 04-09-2001 01:15 PM |
