001 and MIDIMAN Midisport 2x2
I just installed my 001 and let me explain what happend. First I followed ALL the instructions for the installation EXCEPT the OMS installation (because I already had OMS w/ Reason, running in my machine). I re-started the machine, opened PT LE. created a MIDI Track, REC enabled it and there was signal in but I couldn't hear nothing... but the level was moving... then, I installed OMS 2.3.8 (I was using 2.3.7) opened PT again and... nothing... it stoped receiving the signal from the MIDI... any ideas?
------------------ Think Diferente!
Think Diferente! |
Re: 001 and MIDIMAN Midisport 2x2
i bought the midiman 2x2 but it didn't have the drivers in it for the g4 when i bought it.
Humm... It was working GREAT with REASON... but not with PT LE... have you worked w/ MIDI on PT LE?
Think Diferente! |
Sorry, but I don't believe that the Midiman interfaces work with OMS 2.3.8 Try going back to 2.3.7 (Check the midiman website for more info)
I HAVE THE MIDIMAN 2-2 RUNNING FINE WITH MY 001. NO PROBLEMS AT ALL.
Same as above...
http://homepage.mac.com/dkrausz |
Now I can receive the MIDI input put I can't hear nothing... Any ideias?!?!?!?!
Think Diferente! |
Have you made sure that you're aux track for your midi has the right ins and outs assigned? Sometimes it's has simple as a restart. I assume since you're getting a signal, that you have all the necessary drivers for your midiman. Mine works just fine. However sometimes if I'm like at the limit for my plug-ins, my audio will still play but my midi stops. Then even though I take out a plug-in or two, I still have to restart and I'm back. And I am using OMS 2.3.8.
WLTruesongs |
midiman midisport 2x2 | dw drummer | Pro Tools M-Powered (Win) | 3 | 01-01-2006 05:32 AM |
Midiman Midisport 4x4 and Digi 001 PLEASE HELP!! | jessecobra | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-03-2003 07:50 PM |
midiman midisport 8x8 anyone? | nodoze123 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 04-25-2002 04:49 PM |
midiman midisport 8x8 anyone? | nodoze123 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 04-24-2002 11:17 AM |
Anyone using Midiman Midisport 4 X 4?? | yavuzj | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 07-23-2001 06:57 PM |
