Old 05-24-2012, 07:33 AM
Meads Meads is offline
Default Video Satellite LE -> Sync HD required?
I want to get a Video Satellite LE, to put some load off my audio machine.
I would like to run PT9 with Video Satellite LE on my MacBook Pro (2010), do I really need a Sync I/O as stated in the official specs?
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
Old 05-24-2012, 09:02 AM
Kuba Pietrzak Kuba Pietrzak is offline
Default Re: Video Satellite LE -> Sync HD required?
Well, VSLE should work without Sync I/O, but:
ProTools has known "start error", so the sync is not tight each time you press play. A setup with Blackburst/WorldClock generator, Sync I/O and genlockable video card can guarantee, that video will not drift and the sync will be tight.
I think, there is a need for some testing.
Without Sync (and BB gen and Ref in) you will have just a ProTools LE slaved to ProTools HD. Question is, if those 2 independent clocks will tick together without any drift.
Best,
Kuba
Old 05-24-2012, 09:49 AM
nst7 nst7 is offline
Video Satellite LE does not list the Sync HD or IO as a requirement for simple video playback. It only lists it in terms of audio production. Which is confusing, because in the next paragraph it says that using it for audio production has not been tested.
Regardless, you should be okay for just video playback. The Sync units ARE listed as a requirement for the other Satellite products, though.
Old 05-24-2012, 09:55 AM
Okay, thank you, so I just was confused.
Has anyone experience in using it without clock? It cannot be desastrous, since VVTR - which I have been working with for a long time, isn't clocked as well, and works fairly okay.
How about responsiveness. With VVTR I always have a significant lag, when I hit play. How is it with VSLE? Is it locked almost instantaneously, or does it take a moment, until it locks?
iMac Pro
- MacOS 10.14.6
- C|24 | S3 | Dock
Old 05-24-2012, 11:18 AM
Brandonx1 Brandonx1 is offline
VSLE is very responsive. It feels like one session, not two. It works Great. I Highly recommend it.
Old 05-24-2012, 11:23 AM
Well, this is what I did not dare to hope. Will be a very happy man, if this is true.
iMac Pro
- MacOS 10.14.6
- C|24 | S3 | Dock
Old 05-25-2012, 12:37 AM
I also confirm, that "it feels like one session".
As for VVTR, it has ReSync capability, so this means that if video starts to drift in terms of frame boundaries and incoming time code, the software will re sync it on the fly and everything stays in sync even without genlockable video card.
Kuba
Old 05-29-2012, 07:09 PM
vudoo vudoo is offline
I've used Satellite LE on a MBP linked to a PT HD rig for years and never had any problems. Go for it, it's a great set up.
Old 05-29-2012, 07:13 PM
I already got it, and I love it.
Thank you guys for helping out!
iMac Pro
- MacOS 10.14.6
- C|24 | S3 | Dock
Old 05-30-2012, 01:01 AM
MIKEROPHONICS's Avatar
MIKEROPHONICS MIKEROPHONICS is offline
Default
Are you using it with a mojo and or a clock?
Just wondering if I should dip my feet into this VSLE thing as my macro hd3 combo is struggling with a big surround session and video
Cheers
cheers
Mike Aiton BSc (hons)
Dubbing Mixer/Sound Designer
BAFTA member
IPS member
former Post Production Expert at www.pro-tools-expert.com
www.mikerophonics.com
HTML code is On
Satellite Link built into HD - Sync HD still required? nst7 Pro Tools 10 0 04-08-2013 08:23 AM
Video Satellite Ref/Sync issue budster Post - Surround - Video 4 08-25-2010 02:05 PM
sync video with pro tools using satellite le ericlees Post - Surround - Video 6 03-13-2010 09:36 PM
Video Satellite LE sync question vudoo Post - Surround - Video 2 09-23-2009 05:35 AM
Video Satellite LE Sync Problems jmattchan Post - Surround - Video 12 08-22-2009 09:45 AM
