Old 12-03-2010, 01:54 AM
demane22 demane22 is offline
Default Window Configurations
What I'm trying to do is open up all my Pro Tools projects with the same window configurations. I'm able to save the current configuration, Pro Tools spanned across 3 monitors. Monitor 1-Main Project Monitor 2- Midi Editor Monitor 3-Mixer. Coming from Nuendo and Cubase, it was just a matter of pressing Alt + Pad1. When i open up a different or new project, the window configuration i saved it gone.
Can someone please let me know if im doing something incorrectly, or the correct way to accomplish this.
Thanks in advance
-Demane
Windows 10 | i7-4790K | 32GB RAM | 500GB SSD System HD | 2x 2TB Audio HD's
UA Apollo16 | LYNX HILO
Pro Tools 2018.1
Old 12-03-2010, 04:56 AM
Drew Mazurek's Avatar
Default Re: Window Configurations
Store it in your Template or simply import it from any session that has it.
Import Session Data/check the Window Config box in the lower left corner.
www.drewmazurek.com
Old 12-03-2010, 09:20 AM
daeron80 daeron80 is offline
Right. IOW, Window Configs are saved with the session, they're not global prefs. You can also save multiple Configs per session, which can be very handy for those of us still living in the dark ages of only two monitors. It might even be handy with 3. You could have three WinConfigs such that you could have any of the three main working windows in the center monitor. They can be recalled using Memory Locations, so you could, e.g., have .1. bring Edit to the center monitor, .2. bring MIDI to the Center, and .3. bring Mix to the center. Save that in a template use it as your starting place for each session.
David J. Finnamore
PT 2022.9 Ultimate | Clarett+ 8Pre | macOS 13.1 on a MacBook Pro M1 Max
PT 2022.5 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 12-03-2010, 05:23 PM
Great, a little different than what I'm used to, but it works and that's all that matters.
I really appreciate the insight...
Thanks
Pro Tools 2018.1
Old 12-04-2010, 09:06 AM
aboriginal aboriginal is offline
Also, after adjusting your window settings to taste, you can then right-click on PT in the taskbar and choose "close" instead of the usual "file -> exit." Doing this will save your window configuration. Try it.
Hope that helps as well.
_______________________________________________
Win7 x64|HP Z600|2 Intel Xeon @ 2.93 GHZ|24GB DDR3 PC3-10600 ECC RAM|
OCZ Vertex 2 SSD 128 GB 3.5 Sys HD|600 GB WD Velociraptor Audio HD|
1GB Samsung 840 EVO Sample Library HD|
PTHD 10.3.6 & 11.1.3|HD Native Core|Lynx Aurora 16 HD|Dangerous Monitor ST|
UAD2 Octo Core Card
[IMG] code is Off
Window configurations ? jackp Pro Tools TDM Systems (Mac) 1 10-23-2012 02:26 AM
Window Configurations Mac88s 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 28 11-15-2008 08:19 PM
Window Configurations List window stevedresser83 Tips & Tricks 1 09-26-2008 01:32 PM
Window configurations Studio Studio Pro Tools TDM Systems (Mac) 4 10-21-2007 11:01 AM
Window Configurations - useful? lwilliam Tips & Tricks 1 01-23-2007 05:44 PM
