Old 08-22-2005, 04:46 AM
hed hed is offline
Default How to assign different samples to each key??
Sup yall,
I' using an E-mu XBoard 25 and I' wondering how can I assign different samples (for example kick, snare, hi hats...) to each key, so that I could play it as a sort of "drum-machine pads"...please, any help??
H3d
MacBook Pro 2.4GHz, 4GB, Leopard 10.5.5, Lacie Firewire HD250, MBox1 PT LE 8, Apogee Mini-Me, Akai MPC 500 & S2K, FMR Audio RNC, Microkorg, Genelec 8020A
myspace.com/korneliuskeyloid
Old 08-22-2005, 06:06 AM
spkguitar's Avatar
Default Re: How to assign different samples to each key??
It was my understanding that the xboard 25 was just a controller. What are you using for a sound module/sampler? Assigning the samples to keys is usually done at the sampler, not the controller.
Old 08-22-2005, 06:51 AM
hed hed is offline
I'm using it with Kontakt 1.5 (for the moment I'm learnin'to use this one).
I'm pretty new to MIDI tracks concepts and stuff so...can you give some other suggestions on how assigning correctly some different samples??
Thanks.
Old 08-22-2005, 07:32 AM
spkguitar's Avatar
Most of the samples that come with Kontakt are already mapped out to specific keys, drum samples especially. If you're loading pre-made drums samples most (but not all) of them follow the MIDI GM key assignments (for example, see this chart )
If all you want to do is play, I recommend the pre-made samples; they're already mapped for you and you don't have to do so much work. Kontakt comes with quite a few, but one of my favorite free ones is the FREE NSKit from natural studios. Kontakt will load Battery kit maps, so if you download the wav files and the battery map from that page you've got a full drumkit in Kontakt, already mapped to specific keys.
If on the other hand, you are trying to build your own samples, then that is really a lot more complex. Assigning samples to a key in Kontakt is covered pretty extensively in the Kontakt manual (starting on page 54 to be exact). Learning how to use Kontakt might be a topic best suited for the Native Instrument/Kontakt forums though.
Old 08-22-2005, 09:38 AM
hed hed is offline
Thank you man!
Really helpful, I'll try to download'em...
PS: since I saw your gear, would you recommend your Samson Resolv 80a monitors??
I'm askin'you that bcus I'm supposed to get some monitors and I was wonderin'betwen KRK Rockit 5 or Samson Resolv 65a...any suggestion??
Old 08-22-2005, 10:46 AM
spkguitar's Avatar
I like my samsons, but I couldn't compare them to the KRK's as I have no personal experience with those.
My samsons aren't exactly "flat" and took a little getting used to, but once I got comfortable with them I really like them. For the price, I think they're great.
Please don't just go on my advice though; go and listen to them both (a bunch of others as well) if you can. It is the only true way to get monitors that you are going to like and work well for your situation.
Old 08-22-2005, 11:05 AM
hed hed is offline
Thanks.
Yep they're pretty cheap but they should sound good...
btw I can't use those NS mapped samples...which link??
Old 08-22-2005, 11:30 AM
spkguitar's Avatar
After unzipping, the Battery Version should load up in Kontakt as long as you've also got the wav files as well.
I'm pretty sure you could even use the Soundfont version, (however, I would recommend the wavs over the SF)
Old 08-23-2005, 03:47 AM
hed hed is offline
OK, I did that but if I load 2 samples for example an hihat and a snare, they sound together...they're not mapped. Do you think I'm loading'em in the wrong way?? I dunno...I put the wavs in the bat folder and they appear to be there, but no mapping...any other help?!
Btw thanks!
Old 08-23-2005, 06:57 AM
spkguitar's Avatar
Yes, I do.
The files that are in the ns_kit7free-bat.zip file download are battery *.kit files. These are what you would load in Kontakt. The wav files must also be present on the hard drive for these kit files to work, but you never have to load the individual wavs, the kit files take care of that.
The main drumkit has a filename of ns_kit7free.kit
Load that in Kontakt. When you open it, it will probably prompt you with an error message that says "could not find sample" and then give you the option to "find it automatically or locate it manually?". Don't auto locate; press the "Find" button, locate the sample it is asking for in the directory with the wavs you downloaded and select it. It should then prompt you saying "use this path for the remaining samples also?" Click yes to that.
You should then have a drumkit mapped roughly to GM standards: C1 = kick drum, D1 = snare, etc etc.
Assign Samples To Midi Keyboard. imperialcarter macOS 1 02-08-2012 10:29 PM
Can you break up samples and assign to Keys? achapman Pro Tools M-Powered (Mac) 1 01-14-2011 01:43 PM
How do I assign drum samples to midi zv yoda 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 16 04-11-2009 08:58 PM
can you assign plugins from the c24? blumediaprojekt ICON & C|24 1 01-02-2006 07:42 AM
assign ram littlebear 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-09-2001 09:54 AM
