Old 11-14-2011, 11:14 AM
m1a m1a is offline
Default Problem with 003 rack diver
the 8.0.4b driver not satisfied me because it still has some bugs .
until when I should wait Cubase and 003 rack get solved ? otherwise I switch to another products from other manufacturers such as RME . Please just specify a time to wait , it will take 3 months 6 months 1 year ..... how much time I should wait ?
Old 11-14-2011, 11:42 AM
Default Re: Problem with 003 rack diver
Digi/Avid hardware works quite well with Pro Tools, but is not the best choice for use with other DAW programs.
Old 11-14-2011, 12:33 PM
DigiTechSupt's Avatar
DigiTechSupt DigiTechSupt is online now
Question Re: Problem with 003 rack diver
Can you describe the problems you are experiencing?
Have you tried the updated drivers?
Avid Audio Tech Support
Support FAQ
Old 11-17-2011, 08:44 AM
m1a m1a is offline
I was working fine with 8.0.3 and under xp but with newer version of 8.0.3 that recognize windows sound there is a buggy problem that midi controller works with first opened project and when you open second project works too but midi controller stop working when you switch between projects and midi controller of first and second project will stop working.
with 8.0.4b in windows 7 64bit there is midi controller problem.
with the above versions of 8.0.4b there is additional problem that sound get distorted in Cubase and ASIO time usage reach the highest levels that shows over loaded cpu usage and with setting higher buffer size and changing the buffer size distorted sound doesn't get better and due to this problem I have to switch to RME products. please declare a time that when this problem will get solved and until when I should wait .. one month two months.. half a year.. because I like my digi 003 rack and enjoy working with it.
I thinks this issue is a driver based problem with newer drivers because in older versions I did not experience this problem.
Old 03-18-2012, 09:22 AM
Utsav Utsav is offline
I have similar problem with 003 rack on Win 7 32 bit.With drivers late than 8.0.3 Cubase plays audio trough digi 003 ASIO drivers with interruptions and distortion.Vegas and Forge plays, but play marker is frised.Midi does not work out.PT works nice.All kind of tribal dances around this I has have done from changing latencie to full upgrade comp, os, controller IRQs ets.And here I see messages from many people with same, it is a drivers problem .My solution is simple.Avid alows to have a few version of 003 driver in same time, so I just switch in control panel to 8.0. 3. when I am working in Cubase and Sony and change to 9.0....with PT.No t convienient but works.
Problem with 003 rack diver m1a 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-21-2011 09:22 PM
Major comp. problem - considering reverting to 002 rack instead 003 rack, good move? Tbassist4 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-15-2009 04:20 PM
sound diver osx Laurence w schuberth 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-01-2003 04:23 AM
Problem with Digi001, Sound Diver and Pod!!! Alphadog 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-16-2000 10:16 AM
please please help me w/Sound Diver Man Pro Tools TDM Systems (Mac) 3 10-30-1999 12:56 AM
