#21
Re: Digi 002 Power Harness Issue or Firewire Chip Issue?
The light you see on the optical con. is the data led. OUT should be lit.
#22
@Tom, I have It another go yesterday and I could work for about an hour, then it started again. So I set up a camera and left it running, will send the vid to my dealer today and take it from there. My guess after trying to exclude the possibility's are a heat issue. Cheers |
#23
Avid support thinks it's most likely the power harness issue after all, I can bring the unit in as soon as I have a RA number. Looks like this issue is still under warranty even years later. In the mean time helping myself out with my mbox
Cheers |
#24
Good news
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
#25
First time poster, new reader from LA recording school in Cali. I've just gotten a used 002R from craigslist and tested the unit on the sellers setup before I bought it. It worked well on his setup so I think the hardware itself is alright. The issue I'm having is that when the device is connected and powered Windows seems to slow down to a crawl. This may be a firewire issue, as I have little experience using firewire devices, and this would be the first firewire device I've ever used on this PC. The mouse movement slows down to the point of being unusable and only when I power down the unit does normal functionality return. When I was reinstalling Pro Tools to get it recognise the 002R, Windows seemed to be running smoothly all the way to the reset. Is there anything I'm missing from this analysis? The other thing that could be a problem is I don't know if the firmware on the unit has been updated so that could be an issue as well. Thanks in advance guys, I've had the pleasure of gleaning info from the DUC since I was told about it at school and you guys are a tremendous resource for n00bs like us who are just getting our feet wet. Windows XP SP 3 Pro 32-bit, Pro Tools LE 8.03, 002R firewire Last edited by audioninjateck; 04-10-2010 at 07:39 PM. Reason: didn't include system specs |
#26
Update 9:00pm
Have tried to run PT 8.03 after reinstall but it does not recognize the 002R unit. Still experiencing slowdown when the device is connected and powered on. On the unit itself, the green indicator light for sampling rate shows 44.1 which seems normal. The red mute light is on and the unit makes a few clicks as it starts. When I examined my taskmanager, it revealed that for some reason two of my four cores in my cpu were jacked up to ridiculous usage percentages. The first core was locked at near 99%, the second was strangely inactive, and the third and fourth showed signs of sporadic high activity. Naturally because my mouse is nay unusable as i was checking this out, i couldn't take a look at what specific process was hogging all these resources. |
#27
Welcome to the DUC. You really need to post this to a new thread with your sandra report to give people a chance to help you. |
#28
audioninjateck, youre problem doesn't sound like the power harness issue, like Dave said make a post with a sandra report, cheers
Update on my issue, I was wondering if it always take this long for digi to respond on a case report / RA request? Filed my case on friday... I got work to do Digi/Avid ! Cheers |
#29
#30
Digi 002 Power Harness Issue - No Help? | taperocket | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 19 | 08-26-2007 03:33 PM |
Is this the 002 Power Harness issue ? | phobia | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-21-2007 03:21 AM |
002 rack power harness power suplly issue | rockstah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-06-2004 11:04 PM |
Power harness issue | colnago | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-14-2004 02:11 PM |
Power Harness Issue Digi 002R | volts | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-08-2004 01:06 AM |
