Old 04-15-2015, 07:30 AM
jjsoundoc jjsoundoc is offline
Default USB to Ethernet Adapter
I've run out of ethernet ports on a Mac Pro Tower, and need to have another port with static IP for a TC600- integrator plug.
Having a hard time finding a usb to ethernet adapter that will work with 10.8.5 OS. Is there one that someone could recommend?
Thanks,
JJ
Old 04-15-2015, 11:26 AM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
Default Re: USB to Ethernet Adapter
Anker USB/Ethernet works.
IMDB
Old 04-15-2015, 11:28 AM
quadraphonics quadraphonics is offline
I am using a USB 3.0 one from Moshi that also has a USB pass through.
Randall
Thanks,
JJ
Randall Smith
Audio Editor/Mixer
Starz Entertainment Group
Denver, CO
Old 04-16-2015, 04:53 AM
paulo m's Avatar
paulo m paulo m is offline
Thanks,
JJ
Why don´t you buy a small ethernet switch instead? Much more practical in my opinion. Connect one of your MAC ethernet ports and all the rest of the gear to the switcher and that´s it. Just make sure that it supports 1 Gb in case you need it for certain tasks.
Regards,
Paulo M
MAC Studio MAX M1_64 GB RAM_1TB SSD_MAC OS Ventura
Protools Studio 2024.3
Old 04-16-2015, 09:06 AM
Found an adapter that worked with 10.8.5, but not very well. Must be limited speed of usb port. The TC6000 integrator worked on an internal
port without a problem.
Now thinking of plan B, which is to resurrect a pcie magma expansion chassis. I could stick 2-hdx cards and a blackmagic card in it freeing up
slots for another ethernet card and future satellite video.
Old 04-16-2015, 02:45 PM
Jay_uk Jay_uk is offline
Kanex do one. I have their thunderbolt > USB3 adapter
http://www.kanex.com/usbrj45-adapter
Old 04-16-2015, 08:07 PM
Postman Postman is offline
Switch seems like a good idea! One port DHCP, one static, switch as needed?
HTML code is On
USB-Ethernet adapter andreasaidu Artist Series 6 02-18-2011 09:16 AM
USB to Ethernet Adapter with Euphonix mcmix gsilbers Artist Series 3 05-04-2010 10:57 AM
Control 24 w/ USB->Ethernet adapter? The Chinese Pro Tools TDM Systems (Mac) 3 04-23-2009 11:55 AM
USB to ethernet adapter Craig F ICON & C|24 10 12-18-2007 11:11 AM
Procontrol, USB to ethernet Adapter spigots ProControl, Control|24, Command|8 4 02-21-2003 04:49 PM
