Removing demo plug-in and aux track 101 needed
I earlier downloaded a demo for Nomad Factory's BlueVerb reverb plugin for my iMac - I keep getting prompted to 'activate the purchase' each time I open PT, but am unable to trial it as a demo program. Can anyone educate me as to how I can get this off my computer and out of my PT startup? It's becoming a bit of a pest and I don't care to try it anymore.
I'm also hoping someone may be able to give me an aux track 101 (yep i'm a PT greenwood!)- i'm trying to set up a reverb send for some guitar tracks but at this stage have only worked out how to set it up as an insert. I've tried setting up an aux track using the D-Verb plugin but I can't work out how I can adjust each individual track's amount of return/send - is it in the bussing or is it a different approach? A basic question I know but I can't seem to find any online tutorials about it... |
Re: Removing demo plug-in and aux track 101 needed
to remove the plug, go to \\Mac HD\Library\Application Support\Digidesign\Plugins. Find it in the list and either delete (if you don't want it) or move it to the plugins unused folder (if you think you might buy it at some point). Either is fine.
say you have a vocal that you want reverb on, assuming you have everything bussed to Analog 1-2 output:
Mac Pro 3.7 Quad Core Intel Mac OS X 10.13.2 PT Ultimate HDX 2019.10 64GB RAM HDX I/O 16x16 Analog HDX I/O 8x8x8 |
Fantastic - demo plugin gone. Aux tracks working fine too.
I remember seeing a producer being able to adjust the amount of aux send from the channel strip (without opening up a new fader window) - how do I achieve this? Also - what is the standard PT chorus plugin? I see there's one in the audiosuite but I can't seem to find it to patch into an aux channel |
after you put the send on the track, you are turning it up, aren't you? if you click on the send, it will open up a fader. As you turn it up, it will increase the reverb to the send. IF you put all the sends on the same row (send A/the top send across the mix window), you can hold apple and click the button you use to put the send on the track. This will open a row of faders for your sends.
Hope that makes sense.
Perfect - that's what i'm after. Thanks for the help!
Removing PT11 demo? | musicman691 | Pro Tools 11 | 4 | 07-22-2013 08:42 AM |
Removing Unwanted D-Fi Demo Plug-In | phil connors | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-24-2006 01:21 AM |
Removing Expired Demo Plug-Ins *DELETED* | Mike Harrison | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-03-2005 01:18 PM |
Plug-in demo Help needed | Matt Reisinger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-08-2004 07:32 PM |
Removing Demo Plugz? | mick7777 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 11-26-2003 05:58 AM |
