Old 11-12-2007, 01:01 PM
Dstryr Dstryr is offline
Default Instrument Track not syncing
I'm having a problem with a BFD Instrument track that I've been working on.
Everything was fine yesterday, I did about 3-4 hours work and I only got 1 playback engine error the whole time, no glitches, nothing. I did a bounce at the end of the day and the drums were absolutely all over the place. They just couldn't hold together for more than 1 or 2 bars at the most. I mean, even the count-in is really out of time!
This evening it was happening even during playback, but I've got that to calm down now.
In the Playback Engine settings I have my H/W Buffer at 1024 Samples (max), CPU Usage at 85% (max) and DAE Playback Bugger on Level 8 (max). Within BFD, I have enabled 16-bit mode. I did have all samples loaded to RAM but I thought that might encroach too much on PT's buffer space so I disabled it.
I've been fiddling with different potential causes, but does anyone know what the problem is and how I can get by it?
Cheers
D
Wie man mit dem Hammer Musik Macht
iMac 3.06 GHz Intel Core 2 Duo » 4GB RAM » Mbox 2 Pro » PT 10.3.4 » OS X 10.8.3 » Formac 500GB » Alesis M1 Active Mk2
Instrument track picking up my microphone, but not my audio track. raddster Pro Tools 9 5 01-20-2012 04:11 PM
sustaining one instrument track while the second track is not sustained with foot ped nrsjunkmail777 MIDI 0 09-28-2011 06:58 PM
Can't Mute or Change Volume on Audio Track and Instrument track FunkTools 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-10-2010 04:40 AM
Problem Converting Instrument Track to Audio Track Gorbies 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 06-02-2009 09:11 PM
Mono Instrument Track VS Stereo Instrument Track mbox2issue Tips & Tricks 8 04-20-2009 04:21 PM
