Firewire 800 -> firewire 400?
I have an MacBook Pro with FW800 and I´ve just purchased a Digi 003 device. Digi 003 has FW400.
Does it work with a FW800 -> FW400 cable? Will I have to do any configurations? Thanks!
MacBook Pro core i5 2,53 GHz Mac OS X 10.6.3, 4Gb RAM. Digi 003 Rack+ |
Re: Firewire 800 -> firewire 400?
It should work fine. 800 devices are backward compatible, so plugging in a 400 device using a converter cable should cause the port to operate at 400 without having to configure any software.
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
The FireWire 800 port on Apple's computers is backwards compatible with FireWire 400 devices, but requires one of the following configuration options: 1) FW800 port —> FW800 Drive (912 or 924 chipset) —> Out FW400 port on Drive —> Pro Tools LE FireWire audio interface 2) FW800 port —> FW800 to FW400 converter cable —> FW400 Drive (911 chipset) —> Multiple FW400 Drives (911 chipset) as needed for maximum track count —> Pro Tools LE FireWire audio interface When qualifying Pro Tools USB devices we connected the device to the USB port on the computer and used the above configuration guidelines for connecting drives only. Thanks again!
To clarify that, there are certain hard drives that will basically act as an 800 to 400 converter, such as these from macsales.com:
http://eshop.macsales.com/item/Other.../MEAQ7500GB16/ In this case, you use an 800 to 800 cable (this comes with the drive) to the drive's 800 port. Then you use a 400 to 400 cable from the drive's 400 port to the 003. This hard drive with the 003 should work fine like this. The other option, which seems to work better with an Mbox 2 pro, is a drive with 2 400 ports. In that case you use an 800 to 400 adapter cable to the 1st port of the hard drive, then go from the 2nd 400 port of the drive to the mbox 2 pro. |
Thanks a lot! I should do just fine with just the cable then.
Actually, you may not do fine with just the cable, which is why Avid and others are suggesting an external hard drive - you need a separate drive for your audio files; as a bonus, the drive can convert between FW800 and 400.
Regards, Ned Monkey Boy Studios 2019 16" MBP, 32GB, 1TB SSD; OSX 10.15.7; 4TB USB-C G-Tech External Summit Audio 2BA-221, TLA-50 -->Focusrite 18i20 3rd Gen, Eleven Rack, Pro Tools 2021.3 Plugins, Virtual Instruments, and real ones |
What Ned said...
I have a MacBookPro with FW800, OWC Mercury Elite Pro Classic, and an 003 rack. I hook it up: MBP (800) to OWC drive (800), OWC drive (400) to 003 (400) and it works, so far, without incident. Gotta have that second drive! Good Luck. Kevin
Gigabyte GA-P35-DS4; Q9650; Win 7-64; Saffire Pro 40; PT 12 / MacBook Pro C2D 2.66; 10.10.3; PT 11.3.1 |
I have a MacBook Pro and an Mbox 2 Pro, and the only configuration that actually worked was to hook it up like this:
MBP --> Mbox 2 Pro --> HDD Doing it the recommended way only brought constant Buffer issues.
MacBook Pro 2.66 i7, OS X 10.6.3 Mbox 2 Pro Glyph GT 050Q HDD Pro Tools 8.0.4 |
Yes, obviously, you need an external drive in the equation one way or another. If you google around a bit on the terms in Avid's instructions, they'll become clear. Understanding all that stuff is essential to having a good PT experience.
Thanks everyone!
I see... I still don't get why one has to have an extra drive. I did fine whit my Mbox 2 and my old MacBook, no problems there. Exactly why do you need an extra drive? It seems strange when you have bought an expensive computer and an expensive audio interface... you would expect that that should be just fine... (pardon my not always accurate english)
Questions on USB/Firewire speeds on computer W/ No firewire port | rockguitarist1255 | Tips & Tricks | 14 | 04-02-2013 06:35 PM |
Digi 002 Firewire 400speed not accepted by new Mac Pro Firewire 800speed ports | AncientMan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-15-2010 09:31 PM |
Impossible to find SIIG FireWire 2-Port ExpressCard FireWire adapter | Bloody Maker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 02-22-2010 09:58 AM |
Issue? Laptop, Firewire 410, SIIG Firewire Express Card | batchmister1 | Pro Tools M-Powered (Win) | 2 | 08-07-2009 10:37 AM |
More Firewire Formatting/Performance Woes - Anybody got Atto working with Firewire? | Audiobotica33 | Storage Subsystems | 1 | 12-11-2001 07:12 AM |
