AVID MC3 install has sabotaged Pro-Tools!
I installed Avid Media Composer 3.0 yesterday (software/dongle version) and now Pro-Tools (LE 8.0 running off of an MBox) crashes on launch. It appears to be a Library issue... the report states:
Dyld Error Message: Library not loaded: @executable_path/../Frameworks/CFnd.framework/Versions/A/CFnd Referenced from: /Applications/Digidesign/Pro Tools/Pro Tools LE.app/Contents/MacOS/Pro Tools LE Reason: Incompatible library version: Pro Tools LE requires version 8.0.0 or later, but CFnd provides version 7.2.0 My Pro-Tools has worked perfectly since getting it in February so I'm assuming this is related to the MC3 install. Do they share library info?? Is there a workaround?? Do I need to re-install Pro-Tools? Help please! |
Re: AVID MC3 install has sabotaged Pro-Tools!
MC v3.0 and PT v8.0 won't work together.
You need MC v3.5 for a supported co-install with PT v8.0 Co-Install Notes for Avid Media Composer 3.5 and Pro Tools 8.0: http://www.digidesign.com/index.cfm?...5&itemid=37195
If you don't have it backed up, do you really have it? [ Mac Pro 4x2.66 | 3x23" | 5GB | 4x500GB int. - 4x500GB ext. | 10.5.5 | PT8 003R | Command|8 | BM-5A's ] [ Macbook Pro 2.16 | 17" | 2GB | 1x120GB int. - 2x250GB ext. | 10.5.5/XPproSP2 | PT8 Mbox2Micro ] |
Pro Tools will not Install - How do You Download Windows XP Updates from Avid | Dave12 | Pro Tools 10 | 6 | 01-03-2013 11:07 PM |
Avid pro tools 10 hd install file? | bacchus40 | Pro Tools 10 | 0 | 07-26-2012 12:52 PM |
Hey Avid need install answer For PT 10.2 | maxtn | Pro Tools TDM Systems (Mac) | 4 | 05-22-2012 02:07 PM |
AVID: MBox Producer Factory DOES NOT INSTALL in Pro Tools 10 | mixupandblend | Pro Tools 10 | 1 | 11-14-2011 03:12 PM |
avid technoloy install? what do i do? | lert09 | Pro Tools M-Powered (Win) | 2 | 08-17-2009 07:17 AM |
