#21
Re: Is this true ?
The ORIGINAL pci specs were for a 33 mhz buss.. hence the 133MB/sec. There has been the introduction of 64 bit and 66mhz pci specifications, however you typically will find the 32bit, 133mhz pci slots on most consumer motherboards today. The 64bit and 66 mhz pci slots are mainly on server motherboards. So...the only relevant number for the masses is the PCI buss running at 33mhz which would yield 133MB/s And...if you don't believe that consumer boards are only using the 33mhz buss, take a look at the table on this interesting article from Feb. of this year on overclocking the pci buss: http://www.anandtech.com/chipsets/sh...tml?i=1968&p=4 All of those motherboards, at standard FSB speeds are running their pci buss at 33mhz. |
#22
Re: Is this true ?
Gigabyte z390 Designare I9 990K 4.7 GHz 64 Gb of DDR4 3200 Gigabyte RX580 8 Gb Win 10 Pro 15" Mid-2015 MBP 2.2 GHz i7 16 Gb RAM 512 Gb Flash Drive - OS X 10.14.6 |
True Z , do you use it? | timos | Eleven Rack | 9 | 01-24-2011 05:25 AM |
Can this be true? | paul_g | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-29-2010 08:25 AM |
Is this true? Yes or No.... | dchband | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 06-06-2003 05:07 PM |
true or not? | Fave | Pro Tools TDM Systems (Mac) | 8 | 01-27-2003 12:01 AM |
true or not? | outfit | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-02-2003 09:44 PM |
