Re: Record the mix on an audio track
I heard that for recording is another engine that does that. |
Here's my question though, (sorry for the hijack although maybe you all will be interested.) Has the master buss improved over the years to the point that I thought it would be better if you have a 003 to go out adat to 16 tracks to a d/a of your choice to a nice analog console back into PT with 2 tracks. EDIT: I don't have a 003 and I just realized that it maybe only 8 channels through adat but still if you let another d/a do the summing wouldn't that be an advantage?
John Pro Tools 12.5 Macbook Pro & Windows 7 Ultimate 64 Bit |
When i was watching a tutorial awhile back.. the guys showed you how to set up your templates to have a Mix down track... and he mentioned it was a good idea so that when you are done with the last take of your mix for the day, you will already have a quick mix down to burn to CD for the client... instead of waiting another length of the song.
I don't use it... And i don't have anything better then the Digi002r for converters.
-AIM: RS Recordings -Skype: RSRecords | Pro Tools 8 Native | Windows 7 64-bit| Q6600 @ 3.0ghz | 8GBs RAM | Digi002r | Studio Site: Red Sneaker Records |
& I use a Masterlink some of the time myself but just to print... It takes a min for it to burn CDs for ref purposes because it still has to render the file so its almost like a bounce...
MYSPACE ON'EIM LAUTEN MICS & ME DA'TUBE ON'EIM 'IS TAMARA HOME' NO, SHE'S WITH HOBO KEY '' (that dopey green thing) ('we' must start using pronouns) |
But you're summing down in the box. What I meant was only summing down to stems 16 wide. Then taking those stems into a high end analog console and say go into a masterlink. That's just one example though. Also this is just a thought as I'm just wondering about the quality of the summing of the master mix engine in PT. NEW EDIT: SORRY GOT IT!. Correct me if I'm wrong but it looks like I will be using an aurora v16 via adat and the fat lady sings.
@Caruso, u know that u can't use all 16 i/o with the Aurora; U will only be able to use 8 but yeah, summing to a console depending on what it is can definitely be beneficial...& not that it'd make much a matter but u'd be going into the ML analog coming of the console if its a true analog console...
Are you saying I am not getting the true conversion when bouncing down since I am not summing through another analog console? Now i am confused or need drugs
"It aint about the stuff you got..If it sounds right you're finished..Burn it!" For all complaints click here DAW-Digi003 PC-Sweetwater CS dual 3.0/Asus 975X Chipset/CPU dual 3.0GHz/800MHz FSB/RAM 4GB/Radeonx300se/4 internal glyph sata drives/ 3 external glyph backup drives/Acronis True Image OUTBOARD-UA LA-610, ADL-600, Digimax lt, Eureka x 2, Central Station, Hearback x 8, JBL LSR, Monster Power Software-PTLE 8.0, Sound Forge, CD Architect Plugins- Too many and too much money spent |
Maybe a Scottish Terrier.
----------------------------- Wango Don’t piss down my back and tell me it’s raining. http://www.soundclick.com/bands/defa...?bandID=851389 |
Unable to Record (digitize) a Regular Midi Track to an Audio Track | JuicyMusic | macOS | 9 | 02-27-2013 08:52 AM |
Record 1 audio track, then go to record a second, the timer button flashes... help | tdubthatsme | General Discussion | 5 | 02-27-2011 04:39 PM |
PT 9 won't record audio track | SoloMonk | Pro Tools 9 | 9 | 12-13-2010 10:04 AM |
Can Not Record On Audio Track 2... Please Help | Wize Dome | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-24-2007 06:13 AM |
How do I record a MIDI track onto an audio track? | shemcom | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-11-2003 06:13 AM |
