Old 09-02-2004, 12:49 PM
dhlovett dhlovett is offline
Default Anyone using 17\" PowerBook G4 1.5GHz with HD Accel
I am considering the purchase of a PowerBook 1.5 GHz, 17 inch laptop for use with a Magma FireWire expansion chassis. The ProTools system would be either an HD1 or HD2 Accel, and my intent would be to use FireWire 800 drives for recording. Installed memory in the laptop would be 1.5GB, using OS X 10.3.4.
I am aware this PowerBook is presently not qualified, so I know that there is some risk. Still, my application makes such a system very appealing. So...
- Does anyone else use this configuration or one similar?
- Do you have any suggestions for how to make such a system work correctly?
- Are there any pitfalls I need to be aware of?
- Would you recommend ProTools 6.4?
- What track count are you able to achieve with your system?
Thank you for your help!
Dave
Old 09-02-2004, 03:59 PM
RobMacki RobMacki is offline
Default Re: Anyone using 17\" PowerBook G4 1.5GHz with HD Accel
For the record.
My system:
G4 Ti PB 400Mhz
OS 10.2.8
Magma CB4
PT 6.2 HD2 Accel
My little PB 400 is not blessed by Digi but it has been running like a champ since the beginning of the year.
You will most likely be limited in track count. Check here. But I haven't max out my system yet so I can't verify how deep you could go.
Some day my system will grow up to be a G5 dual.
Digi, I would be more than willing to test 6.4 w/ my system to verify.
Old 09-02-2004, 08:14 PM
tha k man tha k man is offline
Although not qualified by Digi, have set up ;
PB G4 15" 1.33/10.3.4
PT 6.4 - HD2, and Magma Chassis
LaCie firewire drives
No major problems to date.
F.Y.I
G5 Dual 1.8 /1.5 Gb Ram
OSX 10.4.7
PT LE 7.3 cs1
DIGI 002
Waves Ren
Sony Bundle
Soundtoys-arama
NI Komplete 3
Powerbook 15", 1.5GHz, vs. 1.67GHz JCBigler 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 06-28-2005 02:21 AM
powerbook g4 1.5ghz 12inch screen ggmmss 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 06-22-2005 08:57 PM
Powerbook 1.5ghz ---vrs--- PC 3ghz a2zproductions 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 11-02-2004 09:12 PM
TDM 6.4 w/ Powerbook 1.5Ghz & magma 4 slot chassis mwingerski Pro Tools TDM Systems (Mac) 19 10-17-2004 11:54 PM
POWERBOOK G4 1.5GHZ WITH PRO TOOLS MBOX Ragpicker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 05-22-2004 12:07 PM
