#51
Also having tragic problems with MIDI in 2024.3.
I'm building a very large session as a backing track, with hundreds of tracks. I record in new layers of backing tracks, which go into folders per song. Usually there is no latency, and notes record where I play them. Since 2024.3, there's latency if I record through the folder. If I bypass the folder, set output to direct output, the sound is correct when I play in, but on playback the notes are way way off. Also have problems as others mentioned with loopable instruments, for instance NI Cuba , and using the loops in that. Not a chance. Have to bounce to audio and repair. Unfortunately I let my support plan lapse so won't be trying 2024.3.1. I thought it was just me and my large session, but yeah.
MacBook Pro: 16GB M1 Pro 8c Hackintosh: MacOS Catalina, i7 6700k, 32GB RAM, RX580 Pro Tools Studio, RME RayDAT PCIe http://www.liamgaughan.com |
#52
Shefi case # 04794967
Shefi Mac Studio M2 Ultra 128GB, OS 13.5 |
#53
weezul is correct though. I'm also having issues with "loopable instruments"...
With Arturia CMI for example, which plays sequences that are synced to the DAW clock, if I use clip looping for a simple whole note that should play the full sequence, only the first loop works. This is a big problem as well! It seems like the only workaround for MIDI printing incorrectly is turning off delay compensation while recording MIDI which is not really a workaround...
Pro Tools Ultimate 2024.10.2 macOS Sequoia 15.2 MacBook Pro 16" Apple M2 Pro with 12‑core CPU, 19‑core GPU, 16‑core Neural Engine 32 GB unified memory 1TB SSD storage Last edited by skylar_battles; 05-14-2024 at 04:38 AM. |
#54
midi latency with ANY plugins [Case : 04772336]
#55
![]() Quote:
The team have sent an Email with the following questions I would like to know more about your concern regarding MIDI Issues on latency on the most recent Pro Tools version, along with your plugins from Fab-filter. Kindly answer the specific questions below so that I can gather more information and assess the issue: 1. Can you please provide me the PTX file of your session? 2. Please send me as well the last 4 most recent PT Logs from that session, which you can extract by following the instructions on the article below: https://avidtech.my.salesforce-sites...o-Tools-System 3. Is the track you are mentioning about a MIDI track with Aux, or an Instrument Track? 4. Kindly provide me the Plugin Name and Version number of the Fab Filter, and the other plugins you put on the specific Insert Channels and Send Channels that were affected by this. 5. Lastly, please send me a video recording showing the issue. I will wait for your responses. Can you try accessing the case through the support portal to respond? Do you have another Email address you'd like to include on the case? Feel free to PM me
-Tope To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support www.topedomingo.com |
#56
Hi Strawb, I've updated the support case. Have you already tried adjusting your buffersize and still get the same latency?
#57
i've rolled back to 2023.12.1 so i cannot do any testing - thats for the techs at avid to fix
#58
![]() Quote:
I responded to your case and have taken it over from King. Since you rolled back... the case is on hold and Tope and I will work with others to pin point this issue and get a bug logged. Thanks, Marianna
Marianna Montague Sr. Dir. CX and Community | Customer Advocate [email protected] cell +1 (813) 493-6800 AOL IM avidmarianna Twitter Avidmarianna We're Avid. Learn more at www.avid.com |
#59
![]() Quote:
I decided to create a separate case for the Loopable issue - case 04803090. I also made note on each case we have open for the Midi latency so the techs can connect the dots. The L2 peeps have also been tagged so we can get their thoughts as we haven't been able to reproduce it and so many of you have rolled back so you can't try it. Marianna
#60
![]() Quote:
I haven’t created a support case yet but would love to help with further testing since I have the Pro-L2 issue on my end. I’ve been jumping back and forth between 2023.12.1 and 2024.3.1 EDIT - just opened a support case (04803116) |
MIDI Thru Latency Issue | The Style Guide | Pro Tools 11 | 4 | 12-08-2016 08:53 PM |
Latency issue with midi function of Mbox3 | deepakkabirgyan | General Discussion | 1 | 12-22-2013 10:29 AM |
Midi Latency Issue - Please help me someone | metro williams | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-23-2010 08:18 AM |
MIDI beat clock latency issue!! | overseasmusician | Pro Tools M-Powered (Win) | 0 | 11-04-2007 04:57 PM |
