#181
thanks for the clarification, maybe i''l try it one more time in 2024.10.1.
but not one avid tech (of the 6 i've dealt with on this issue) has mentioned this option. my video example shows a situation where the drum beat is played in time while recording, but the midi notes are recorded late and thus playback late. i have a feeling its something else, but i will let you know after i do some tests. Quote:
#182
I really REALLY hope this gets resolved in the next (2025.02 maybe?) update. If not, does anyone have a reliable workaround for the time being? The amount by which the MIDI gets printed after live recording it doesn't seem to be consistent to me...
#183
just got this email (unprompted) from avid tech support RE BUG PT-262860
Entered on: 2/20/2025 4:46 PM Entered by: Francis Ben Hello. This case will now be closed as the bug fix will be available on the next Pro Tools release. Best Regards, Benjie AVID Pro Tools Technical Support what?????? a future update will solve this problem? how can a case be closed without it being resolved? this is nuts.... 1st: release the update and lets see if the problem is fixed. 2nd: if the problem is fixed then close the case 3rd: if not, then the case is not closed |
#184
![]() Quote:
~Will |
#185
ok fingers crossed that pt 2025 does the trick
#186
![]() Quote:
I can confirm that the bug is fixed and will be rolled into the next release of PT. I can also confirm that a few others related were also fixed and are: PT-262860: MIDI incorrectly placed on timeline, determined by H/W buffer setting PT-329836: MIDI Virtual Instrument Recording Always Sounds EARLY on Playback PT-201867: Recorded live MIDI from VI is not aligned with audio. Not exactly sure when the next release date-wise but Im going to follow it and you can also email me to check on it (email is below). Normally tech closes the case when they are informed that the bug is fixed so they can alert the customer so they know it is coming in the next release. As Will ( smurfyou ) said.... some don't get resolved so this is a good thing! Marianna
Marianna Montague Sr. Dir. CX and Community | Customer Advocate [email protected] cell +1 (813) 493-6800 AOL IM avidmarianna Twitter Avidmarianna We're Avid. Learn more at www.avid.com |
#187
These would be very exciting, welcome and long overdue developments!! Very cool. So, would these bug fixes collectively be considered part of the overall "fix MIDI ADC" issues we've been having for so long? Or is that its own separate bug? I have a hard time keeping all the MIDI issues straight...
-------------------------------------------- Mac Studio M1 Ultra 64GB RAM, Pro Tools Ultimate 2023.12.1, Ventura, Apollo x4 / Avid HD IO 16x16 w/ HDX, UAD Octo |
#188
![]() Quote:
There are still some issues with MIDI that are still in progress but the ones above are their own individual bugs which are closed/fixed. My hope is additional issues are also closed/fixed before release (and no I dont know what that date will be ). Engineering is working super hard to get as much as they can resolved but it depends on complexity and dependance. Anyone can always ask me about a specific issue thru email or PM. Marianna
#189
Thank you so much Marianna. Can't stress how critical this was. Looking forward to the release.
#190
Hi, I have something similar, When using pro tools to record or play any midi instruments / Drums /Keyboards and external, Guitars & Microphones or vocals, there is so much latency problems , I have changed the buffer size to 32 and even placed the tracks in low latency mode but the issue continues and this is unusable for me as trying to finish many projects for clients I am working with, I have tried this with Logic 11 and no problems at all, please can you help asap, I was going to try updating macOS today but thought I would hang back to see if this can be resolved
MIDI Thru Latency Issue | The Style Guide | Pro Tools 11 | 4 | 12-08-2016 08:53 PM |
Latency issue with midi function of Mbox3 | deepakkabirgyan | General Discussion | 1 | 12-22-2013 10:29 AM |
Midi Latency Issue - Please help me someone | metro williams | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-23-2010 08:18 AM |
MIDI beat clock latency issue!! | overseasmusician | Pro Tools M-Powered (Win) | 0 | 11-04-2007 04:57 PM |
