Old 08-29-2014, 01:51 PM
mrallen43 mrallen43 is offline
Default the repeat option inside soft key command does not work
According to the manual if I set the "repeat" option (In this case I set it for as fast as possible), I should be able to hold a button (in my case it is the numeric keypad on the MC Transport, and it will increase or decrease incrementally for as long as I hold keypad down. This does not seem to be functioning! Does anybody have this issue?
Thanx
PT11 hd 11.2.1
OS 10.8.5
Eucon3.1.3
The latest Eucon Firmware
Old 01-30-2016, 08:23 AM
Normann Büttner Normann Büttner is offline
Default Re: the repeat option inside soft key command does not work
I know this is a very old thread, but I do have the same problem. The last version I know of where "repeat" for the soft keys worked was EuControl 2.6.2. In all V3 of EuCon I know repeat is not working
MacPro 5.1, 12GB, OS 10.8.5 HDnativePCIe, stepped back to Pro Tools HD 10, Machine Control, Euphonix Control V2
www.meloton.de
Old 01-05-2017, 06:25 AM
XJENSEN XJENSEN is offline
Sadly, after 3 years, this is still not fixed. I just opened another support case with Avid about this:
The Repeat key functionality (manual page 21) seems to be broken, at least for Numpad keys, on the Artist Transport on EUControl 3.5.0. This is very unhandy when having to perform excessive nudging, requiring a *lot* of key presses on the Numpad (which can't be good for the Transport unit either).
Old 06-08-2024, 07:34 PM
rantanplan rantanplan is offline
After 10 years, still not fixed. At least not for commands attached to shuttle wheel positions. Eucontrol version 2023.11.0.121
D-Command Soft Keys Deleting Themselves MixMonster ICON & C|24 1 10-29-2011 03:27 AM
Audiosuite Plug-in list - repeat repeat.......... sound01 Post - Surround - Video 2 11-13-2006 01:05 AM
Repeat Paste to Fill option in PT7LE? Captain Audio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-19-2005 08:27 AM
Disk meter inside pro tools doesn't work Escape 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-12-2005 08:26 PM
For MIDI: Repeat to Fill Selection Command???? Felix the Cat MIDI 0 02-10-2001 02:00 PM
