Old 10-23-2001, 09:11 AM
swivelhead swivelhead is offline
Default jack input problems
i had all the left side input channels go down on my 001, fiddled with the inputs and a level appeared (intermitantly). contacted digi in the uk and they said it is a common problem and that my jacks weren't of a high enough quality (we're talking about a pretty decent brand new loom here, not crappy old guitar leads) and that the only solution was to go and blow more cash on gold plated neutric jacks.
anyone else had this problem ?
personally i'd say the inputs of the 001 are not of a high enough quality (my friend uses the same loom with a motu with no probs at all). add all this to the lack of dp functionality and i'm rueing the day i chose digi
the cost of the gold neutrics is going towards a swap to motu, in the meantime i fiddle about round the back of my digi trying to get an input, reminiscing about the good old days using battered hifi equipment [img]images/icons/mad.gif[/img]
G4 533 DP(Disabled)
256MB
LAP5
Adaptec SCSI
Old 10-23-2001, 03:25 PM
Michael Cottrell Michael Cottrell is offline
Default Re: jack input problems
Somewhere over the rainbow...
Maybe someday audio components and equipment will communicate telepathically. Until then we will all suffer the trauma of tolerating tangled webs of snarling and crackling wires and cables. Even the most expensive suffer from quality control variations.
I never met a cable I liked or didn't have to repair at least once.
Waaaaaaaa [img]images/icons/rolleyes.gif[/img]
Old 10-23-2001, 04:06 PM
tallbobsmoke tallbobsmoke is offline
aerosol contact cleaner is some pretty wicked stuff. try spraying it on the offending cords and give the inputs the old in out a few times. you might bring the inputs and/or the cords back to life
tallbobsmoke
www.tallbobsmoke.com
Old 10-24-2001, 12:22 AM
Mr T Mr T is offline
Just a stupid (but unexpensive) thought: have you tried to switch cable(= put the jack previously pluged in the right input, and apparently working, in the the left input) and see what happens?
Some music?... http://tmweb.free.fr
Old 10-24-2001, 07:31 AM
DigiTechSupt's Avatar
Here are the specs on the Analog jacks of the Digi001:
-The stacked TRS jack we currently use on the 001 is a Cliff Electronics part number CL1125W.
-This is a standard TRS jack which has internal contacts for Tip, Ring, and Sleeve. When you insert your 1/4" plug into the jack, each separate part of the plug should be touching the respective T, R, and S contacts.
Shoulder of the 1/4" TRS plug fits against outside of plastic threaded housing.
Depth of plastic threaded housing is 9.35mm.
Distance to first contact from inner edge of housing is 4.25mm.
This means that the total distance from the outside of the housing to the first ("S") contact is 13.60mm.
The next contact is 6.35mm away from the first contact.
This means that the total distance from the outside of the housing to the second ("R") contact is 19.95mm.
The next contact is another 6.35mm farther from the shoulder.
This means that the total distance from the outside of the housing to the final ("T") contact is 26.3mm.
Brent
Avid Audio Tech Support
Support FAQ
Old 10-24-2001, 08:09 AM
Burton Burton is offline
If you're using a HOSA snake, that will account for the problems with intermittant signals.
Old 10-24-2001, 04:25 PM
insta-fame insta-fame is offline
some 1/4" male ends insert too far into the 001 plug sockets. you can work around by putting rubber bands around plug ends to prevent full insertion. or buy different cords.
Old 10-25-2001, 07:03 AM
Doug Ring Doug Ring is offline
This happened to me too. I had to patch a small mixer in quickly and used a mixed bag of leads. The fault was on the one channel not fed by a Neutrik jack.
They cost more, but they really are "lifetime jacks".
Jack Input on Rack 003 as a DI Matt Darcy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-20-2008 05:47 AM
OT: Hi-Z input vs regular jack socket Nad4 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 01-22-2004 03:52 PM
G4 733mhz Mic input jack...??? tomayto Digidesign Hardware & Software 1 07-01-2003 03:46 PM
Mbox input jack problem Tim Glasgow 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-11-2003 01:22 AM
jack input problems swivelhead 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-25-2001 01:10 AM
