Old 07-17-2024, 01:53 PM
subwoof subwoof is offline
Default 30 fps to 24 ps convert
Am I wrong, or are audio files mixed at 30 fps the same speed as 24 fps, and therefore the sync should be the same?
Michael McDonough, M.P.S.E.
Michael McDonough Sound Design
Old 07-17-2024, 02:12 PM
JFreak's Avatar
JFreak JFreak is online now
Default Re: 30 fps to 24 ps convert
Video is synced by frames (leading edge), audio is synced by samples.
For 48kHz sampling rate and 24fps video, each frame contains 2000 samples of audio. For 48kHz sampling rate and 30fps video, each frame contains 1600 samples of audio.
Both footage should play at same speed on their own, but if you need to get both of the video working together, you need to either convert 30fps to 24fps or 24fps to 30fps, so both are the same when you use them.
Janne
Old 07-17-2024, 08:46 PM
fork-media fork-media is offline
if you find you are losing sync due to a frame change in video, I seem to remember having to create a new project then importing the old one. and in the import options you can apply pull up or pull down to solve..
2023 Mac studio M2 ultimate - 64Gig Ram 500Gig int SSD
Ultimate 2023 09
Old 07-17-2024, 09:56 PM
BScout BScout is offline
Seconds are seconds no matter how many frames are going by.
That is, as long as no one is speeding up or slowing down the frames but are actually converting them too. (The UK used to run 24fps at 25 fps with no change so the movies were a bit shorter and the pitched shifted)
The 0.1% pull up/down (24/23.976 or 30/29.97) was/is different because it was running the frames faster or slower which is why sync would go out but not the same thing as 30/24 where the fields/frames are divided/multiplied to cover the same length of time.
Pro Tools Ult 2024.6, HDX 2, MTRX/SPQ, SyncHD, DNxiQ, RME BBF Pro + MADIface ProS1 x 2, Fire Max11 x 2, Dock, iPad Air5 Mac Mini 14,12, 12 core, macOS 13.6.9RAM 32GB, SSD 4TB, GPU 19 coreQNAP TVS-872XT 148TB TB3
Old 07-19-2024, 12:38 PM
Thanks for your input!
Old 07-20-2024, 02:06 AM
mfranken's Avatar
mfranken mfranken is offline
Sounds In Sync
Yes but true 30 FPS is for B&W TV. Colour TV (NTSC) created the frame rate of 29.97 so I'd check if your audio files were mixed at 30 FPS or 29.97 FPS.
Mark Franken, MPSE
Dialogue editor/supervisor IMDb
Creator of 'EDI' applications for sound post editors
www.soundsinsync.com
Old 07-20-2024, 04:33 AM
JFreak's Avatar
Yep, NTSC sucks in so many ways. Glad US got 720p faster than EU, but in here PAL (576p) was already so much better we could wait for 1080p.
Janne
Old 07-23-2024, 10:24 PM
mgoorevich's Avatar
mgoorevich mgoorevich is offline
This advantage is derived from domain power utility.
Here is PAL world, we have 50 Hz 220V which is much better than 60Hz 110V (in US)
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3
MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM
MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24
Old 07-24-2024, 07:13 AM
smurfyou smurfyou is offline
The only real difference is it takes our kettles twice as long to boil
~Will
Old 07-24-2024, 07:54 AM
JFreak's Avatar
Whi is telling you bedside stories?
Janne
HTML code is On
SSL's Pro Convert... The Weed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 02-16-2008 03:42 PM
SSL Pro Convert JSR Pro Tools TDM Systems (Mac) 4 01-20-2008 06:14 AM
Convert 192 kHz to 96 kHz? StudioRat81 Pro Tools M-Powered (Win) 0 12-16-2007 08:52 AM
Best way to convert from 44.1k to 48k? dubaifox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-02-2007 01:00 AM
Mac Convert MacConvert 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-27-2001 08:56 PM
