![]() Quote:
https://youtu.be/9ysJzeUG8Ek?feature=shared
This is the popping sound. Just trying to play you tube. The audio shows on S/PDIF output but not sure that has any impact. This is the same kind of popping it get when pro tools is engaged. It makes recording impossible https://youtu.be/CYtBi5AurCM?feature=shared this is what latency mon flags...not sure if it's a proper test but it does detect the audio problem I experience |
![]() Quote:
Another thing is that in your video, you have both Youtube and Pro Tools running, so I'm guessing you are using the MBox as your default Windows audio interface. You can try to set Windows not to use the MBox as your audio interface, then try just Pro Tools alone to see if the pops go away. It's also kind of interesting that in your video, you get an audio pop just about every time you click the mouse, which makes me wonder if the sample rate is switching back and forth since you are trying to share the interface. |
Pro tools is not running
SAMPLE RATE is fixed and stable in MBOX ....does windows have options for sample rate?
#16
![]() Quote:
#17
![]() Quote:
I blocked windows from using any audio, and things have improved considerably. Gonna let this run for a while to verify. Still the odd pip but about 80% reduction. Going to restore original operating system and start again with a clean slate. Dell wants this done to veryfy the operating system. |
#18
![]() Quote:
S/PDIF Out has no way of telling if anything is connected, it's a dumb digital I/O port it just sends what it is told to. Likely you have output mirroring enabled in the MBox. That output will be clocked from whatever you have clocking set up to, presumably the MBox internal. But you tell us exactly what it's set to. |
#19
Thanks for the video.
As Will mentions that correlation with the mouse clicks is very suspicious. Can you test this again with Pro Tools, with absolutely nothing else accessing the device/driver. Widows sound is set to a different device, no other audio apps are running. As many as possible other apps all exited. [Edit, and I see you already tried that... and so...] If that still has issues with only one app accessing the interface I would work to exclude the graphics system/NVIDIA card/driver being a suspect. Just to try something different switch to the Intel internal GPU. Try the latest NVIDA driver you can get, including early release drivers. I would try all that before doing busy work like reloading OSes. --- [edit:] And assuming you are going to record stuff, you need to actually test Pro Tools doing that, and test at the HW buffer sizes you might want to track at. For playback only things Pro Tools silently defaults to a 1024 or 2048 size playback buffer (aka the "disk playback" buffer) regardless of the size you set for the H/W Buffer in the playback engine dialog. When you have a track in record or input monitoring Pro Tools routes that signal uses the low-latency H/W buffer size you are setting. --- And just because Microsoft are wrecking their own products... as you get stuff set up make sure your user account/desktop is *not* using OneDrive. Last edited by Darryl Ramm; 07-15-2024 at 02:19 PM. |
#20
So...good news bad news.
Good news ---- Following JunkGear query about mouse-click and popping, I blocked Microsoft from using any MBOX input or output, and after running for a bit, there was no popping. I started the protools project I used for the test record, and after a short run it appeared to be OK. Bad News: Dell tech has been trying to resolve it from their side, and they had me run one of their remote fixes to resolve a driver issue. It wiped out AVID, and Ilok, and Link. Now ILOK won't let me use the licence. So....I'll end this here, and when I get the machine running again, I'll start a new thread (PART TWO). Thanks for the help. I have learned a lot in a few exchanges |
***Lynx Aurora 8 w/Adat Card, Dsub XLR cables & Optical cables*** | RuffJazzRecords | Buy & Sell | 2 | 08-17-2013 05:26 PM |
Any issues running Digilink cable in conduit with audio cables vs power cables? | ragbor | Pro Tools TDM Systems (Mac) | 2 | 09-07-2009 10:44 AM |
Running Audio Cables....Help!!! | Hricco | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-07-2003 06:10 PM |
Virtual Audio Cables? | cwild | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 08-06-2002 10:40 AM |
HOW MUCH $ ARE THE Y AUDIO INTERFACE CABLES? | juneaudio | Tips & Tricks | 1 | 05-08-2000 09:48 AM |
