Hi, New guy here,...trying to setup my midi instrument patch lists in PT.
I had the lists I was using in DP opened them in Cherry Picker and then exported as PT lists in the correct Digi patch name folders,...the devices are setup in Mac AMS, and showing. Following the manual, when I click on the midi track that's output to midi device "none" to load a device lis.. I get the following message "Midi Server patch file, bank or mode information not available for this Midi instrument" Can anyone offer some help here? Thanks in advance. Pete |
It may help if you tell us what device you are talking about.
Also the "Digidesign Device List.middev" file may need to be altered to point to the "xxx.MIDNAM" file that you are creating with cherry picker. File name references need to be exact. Make a copy of the middev file before altering it. Read through this thread, too.
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
thanks Flommer,
I'm using a motif es, fantom XR and roland Jd 990,.. I have custom patch names created in the banks. Not sure I know how to edit the middev file? thx Pete |
yeah,.. I followed the tips in that thread, not happening..
wish this were easy to do |
flommer,
when you say "pointing to the midnam file. How is done. I put the midnams into the correct folders that PT installed. isn't that the way it should work? thanks again Pete |
I got one synth imported ,.. now whenever go to the list PT crashes instantly WTH!
figured it out,...thanks for the link and help Flommer.
Pete |
Sorry to be slow to respond, but it was probably better that you worked through it for yourself. Glad you got it working.
yep,.I deleted the devices in AMS and recreated them and all went fine.
thanks again Pete |
External MIDI device patch lists Win 7? | ChuckS | Pro Tools TDM Systems (Win) | 4 | 12-10-2010 02:21 PM |
How to publish new OMS patch lists? | Last Legend | Pro Tools TDM Systems (Mac) | 1 | 11-04-2002 07:47 AM |
Patch Lists for OMS | mohoman | MIDI | 2 | 01-25-2002 04:35 PM |
OMS Patch lists | mohoman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-24-2002 10:09 PM |
