Old 02-23-2007, 09:02 AM
Ardillu Ardillu is offline
Default HELP: Video Sync/Spotting Issue
I'm having problems trying to place my video exactly on a marker in a Pro Tools session.
I'm running Pro Tools v7.2 on an HD2 system with sync I/O.
When importing DV movies, and trying to place them at my 2 minutes marker, it NEVER lets me place it right at 2 minutes and is always off by 646 samples. I'm in slip mode, but it almost feels as if it were respoding in grid mode.
It won't even work by placing my timeline insertion marker at exactly 2 minutes and control clicking on the video file to move it there.
In Pro Tools v6.9 we never had this issue and were able to move our video in single sample increments.
Is anyone else having this problem. Can anyone help?
Much appreciated.
Steven
Old 02-23-2007, 09:10 AM
tj_davies tj_davies is offline
Default Re: HELP: Video Sync/Spotting Issue
How did you place your marker? By entering the timecode into the transport or by clicking your cursor into the edit window?
If it's the latter, then you probably should try to enter the timecode into the transport and then adding the marker. As otherwise your marker could be slightly off frame and therefore your video can't be spot on the marker.
Hope this helps.
Timothy
Mac Studio Ventura 13.6
PT 2020.12.0
www.pearls-music.com
Old 02-23-2007, 09:48 AM
Hey Timothy,
Thanks for your quick response. Unfortunately this solution doesn't work. I created my marker by entering the Timecode into the transport and then creating the marker.
Any other solutions you can think of? I'm wondering if it's gotta do with version 7. I never had this problem when running v6.9
Thanks!
S
Old 02-23-2007, 11:47 AM
JanuS JanuS is offline
Maybe switch out of Slip mode, go into Grid mode and drag the region to your desired Timecode?
(and switch back to Slip mode)
But... this might be too simple thought...
Old 02-25-2007, 10:31 AM
Still not working. Does anyone else have this issue?
Thanks,
Old 02-25-2007, 11:19 AM
JKD99 JKD99 is offline
Default Re: HELP: Video Sync/Spotting Issue *DELETED* *DELETED*
Post deleted by JKD99
Joe Milner
Puget Sound, Inc.
Los Angeles
IMDB
Puget Sound on Facebook
Old 02-25-2007, 12:05 PM
minister's Avatar
minister minister is offline
you can only put video on a frame boundary.
can you detail your settings for us? pull down? locked to black? internal? wc? frame rate? drop? etc...
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
PT10 Video sync issue Crossleyj Pro Tools 10 4 09-16-2013 08:42 AM
Weird video sync issue mentalsanityoff Post - Surround - Video 5 05-17-2013 07:57 AM
23.98 Video Sync Issue Cheesehead Post - Surround - Video 8 11-07-2012 03:02 AM
PT Video Sync issue - am I doomed? ergalthema 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 11-25-2009 07:34 AM
video sync issue in PTLE glankrudolph 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-18-2007 08:53 AM
