Old 06-11-2024, 09:02 PM
Scott G Scott G is offline
Default How room size affects my mix
My question is how room size affects my mix.
I recently mixed a documentary for TV in a studio on nearfield speakers that was approximately 4.5m x 4.5m squarish. It was then played in a large meeting room that would seat approximately 75 people with very high ceilings. On playback I found the music beds and sound effects were much quieter than when I mixed it and I’m just trying to work out if that’s an issue with the PA system or just the physics of the room. I know that mixes for TV and mixes for cinema should be done in different size rooms and at different levels and I wondered if that’s what’s going on here.
Thanks
Scott
Auckland New Zealand
PT2022.5 Focusright RedNET 8Pre, RedNET R1
Z690 AERO D Workstation, I7 3.6GHz 12 core, 64GB RAM, Win10 Business 64bit
Old 06-11-2024, 11:08 PM
dr sound's Avatar
dr sound dr sound is offline
Default Re: How room size affects my mix
Put your room dimensions into this and see what is happening in your mix room:
http://www.mcsquared.com/modecalc.htm
That is where the Mix issues are.
Marti D. Humphrey CAS
aka dr.sound
www.thedubstage.com
IMDB http://www.imdb.com/name/nm0401937/
Like everything in life, there are no guarantees just opportunities.
Old 06-12-2024, 06:37 AM
fossile's Avatar
fossile fossile is online now
there's a couple of possible factors - is your mix room calibrated to proper levels and generally the frequency response and RT? is the listening room calibrated as well?
it's possible the levels in the mix room were higher which meant you may have mixed things quieter. or the listening room system cannot produce enough levels with conforming audio sources. cross-checking with calibration audio and/or reference audio will help.
a square room can be less than ideal - but sometimes it can assist especially with smaller or lower powered monitoring as the "room gain" and "LF reinforcement" can actually help - however - you need to test to determine if the effects are beneficial or not.
Glenn
www.runnel.com
www.reverbnation.com/fossile
Old 06-12-2024, 07:28 AM
smurfyou smurfyou is offline
Could be several causes as mentioned.
Was this a stereo mix or 5.1?
What is the playback system? Speakers / b-chain specifically. "Meeting room" to me could mean soffit mounted loudspeakers, small recessed ceiling speakers, or a portable PA setup.
Have you done it before or is this the first time listening in this room?
~Will
Old 06-13-2024, 08:20 AM
paulo m's Avatar
paulo m paulo m is offline
Thanks
A lot of TV shows are mixed in smaller rooms. Your translation check should be on an average living room with sound coming from the TV itself or from a home cinema setup, soundbar etc. Not in a room that was mainly used for a presentation and that doesn´t represent the final audience target of the mix.
Having said that, despite proportions, you should check if your room acoustics have minimum specs and balance frequency wise, reverb time etc.
Also, mixing SPL also affects your perception of the mix. For rooms of the size you´ve mentioned, I personally would mix between 73 and 79 SPL C weighted/slow. Adjust the SPL on each of your monitors and stick with it at the same level during the mix.
Regards,
Paulo M
MAC Studio M1 Max_64 GB RAM_1TB SSD_MAC OS Sonoma 14.5.
Protools Studio 2024.3, Logic Pro 11.
MOTU M64 and Merging Technologies Sphynx2 converters.
HTML code is On
Minimum Size Room for Listening Nathan W. Post - Surround - Video 3 08-29-2017 06:26 AM
Loudness and room-size was: TV-Mix for Theatre Frank Kruse Post - Surround - Video 94 01-09-2011 05:15 PM
Solo in control room affects headphones mix.. Jj Cichon ICON & C|24 3 12-28-2007 02:30 AM
drum recording room size rems 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-11-2003 02:45 PM
Control Room Size? seeds Tips & Tricks 24 07-06-2002 03:19 PM
