Hardware compressor with Mbox2 Pro
If I want to use a Hardware compressor as an Insert in Pro tools, I need to connect it to Line L or R, and one of the Line outs on the mbox2pro, correct?
Re: Hardware compressor with Mbox2 Pro
bump
bump
You need to use ins and out that have the same number. So, for example, connect Mbox output #3 to your compressor input (assuming it is mono - use 3 and 4 for stereo) connect compressor output to Mbox input #3. Use balanced cables (they have two black rings around the connector). In the Pro Tools I/O setup you can setup and name this insert - then that name will appear in your plug-in menu.
In the plug-in menu, on the track where you want it inserted, scroll down to i/o and select your compressor either by name or by the input/output number you used. I think that should do it. Let me know if any of that doesn't make sense. Tom
Tom Lynn my music: www.tomlynnmusic.com other people's music: www.headphonomenon.com |
002rack with hardware compressor | -Dialogue | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 15 | 04-16-2010 04:30 PM |
MBox2 Mini - Upgrade Hardware to MBox2 Pro | gjmunro | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-14-2009 01:09 AM |
Mic pre amp vs hardware compressor ? | chrisdee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 12-10-2008 01:19 PM |
Hardware (tube) compressor ? | ISedlacek | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 09-10-2002 08:58 AM |
Best Hardware Compressor....... | Machead | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-02-2002 04:15 PM |
