Can\'t even run one soft synth after 10.4.10 update
I know Pro Tools LE isn't qualified with 10.4.10 and I've already checked out the link here http://duc.digidesign.com/showflat.p...art=1#1153458.
On my Mac G5 I've set up Ivory properly running from a MIDI track, to Ivory on an aux track, routed to an audio track but I can't get it to record. In fact I can't hear any audio. If I put Ivory directly onto the audio track, DISarm the Record button, I can hear audio. But if I arm the track and try to record, the meter doesn't move and no audio will record. I know it's setup properly because this is how I've recorded Ivory for the past year, I presume the problem occurred from updating OSX. Also, if I try rewiring Reason I can load ONE sample and Pro Tools will play back fine, but if I try switching to another patch, Pro Tools will lose communication with the 002 and the Apple loading-pinwheel will run infinitely. I read in another thread that updating the firmware could help. How do I find out what version I am currently on? |
Re: Can\'t even run one soft synth after 10.4.10 update
Is Low Latency Monitoring switched on?
I can run allot & I am using 10.4.10. No problems what so ever.
You can see what firmware your on by going to The Apple in the top left>about this Mac>More Info.> in hardware overview u can see it, it's called SMC Version. |
Soft synth RAM and PT | ricren | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-10-2004 02:22 PM |
Soft synth vs Hard synth! Reason, Pro 52, V Statio | Jak | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 11-08-2003 10:51 AM |
What would be the perfect (Plugin, Soft Synth, Soft Sampler Library)? | rtcstudio | Pro Tools TDM Systems (Mac) | 3 | 11-16-2002 07:57 PM |
Soft GM synth?? | Kev | MIDI | 0 | 03-08-2002 01:35 PM |
Best Soft Synth Please | Dutchmuzik | Pro Tools TDM Systems (Mac) | 7 | 09-28-2001 11:15 PM |
