Old 03-02-2012, 01:30 PM
Brandonx1 Brandonx1 is offline
Default Can you change the color of buttons on the mc?
Hi All,
Is it possible to change the button color on any of the artist controllers? I have them all. I don't like the transport layout on the mc transport and ah e switched the transport buttons to my liking. Now the play bilutton is yellow the ff button is red. I'd like to change the button color to match the transport function. Can this be done?
Thanks
Old 03-10-2012, 03:54 AM
GW GW is offline
Default Re: Can you change the color of buttons on the mc?
Transport -
the 3 bigger middle buttons you can change between yellow and green.
the 2 + 2 smaller ones on the side you can change between yellow and red.
Why you cannot assign the orange startup colour, i have never gotten an answer on that one.
PT 12.4.0, iMac 27" Retina 4GHz i7, 32GB RAM, PoCo x8,
Digi002 Fact., Logic X|FCPX|Motion
Plugins: Waves Diam. V9|Artist Sign Ser.|SSL|GTR3.5, TC MD3|Harm4|VSS3|DVR2|Nonlin|Unwrap, Sonnox Infl|Dyn, Autotune
VI: Reason 8, Ivory It., Trilian|Omnisphere, VG2/RealGuitar, Kontakt6|GPO, Goliath|Gypsy|Fab Four, Candy, Structure, EZdrum, BIAB Audiophile
Hardware: TLM49|TLM103, SPL Track One, TC M-One, Artist Contr.v2|Transp|3xMix
Old 03-10-2012, 07:33 PM
Ok so how do you change the button color? Also can the buttons on the control change color?
Thanks for the help
Old 03-13-2012, 11:28 AM
Xill Xill is offline
Location: Planet Earth, Milky Way Galaxy, Observable Universe
Thanks for the help
1) Softkeys / Colors
2) of course not.
Old 09-03-2014, 03:02 PM
lucienpalmer lucienpalmer is online now
I was having a problem with getting to colors to change. Then I found this on pg20 in the user guide. Hope this helps anyone else looking for this:
Color
Click the Color button and select a color from the dialog for the selected key. This color is used to color the key in EuControl, not on the surface.
The Soft Keys light yellow in their active states and are unlit otherwise. The Transport keys can each light with two colors. The two outer keys on each side can light yellow or red. The three center keys can light yellow or green. If an alternate color is selected, the surface key uses the closest allowable color (yellow/green or yellow/red) or defaults to yellow if the color selected is not close to one of the two allowable colors.
Old 11-26-2014, 05:37 AM
moberlin moberlin is offline
Hello everybody.
I have a general color issue with my Artist Transport under Win8.1.
(Actual firmware and driver v3.2.1.)
The colors of the transport buttons never light up, regardless which color
I pick in the settings for each button. When I fire up the transport in test mode they all light up, so the hardware is not broken.
The assignment works (in Sequoia): play/record/etc. follows the appropriate button, but the buttons stay dark. It would be easier to hit the right spot with lights on, I guess that's the reason they once illuminated the buttons. :)
But transport just doesn't follow its EU control settings.
Any help?
Thanks in advance,
Martin
Old 11-26-2014, 09:21 AM
Yes, thanks, pretty close to my problem, and perhaps it's the same issue.
I would already be glad if ANY color would show up... :)
control buttons that light up/change color jesse p Artist Series 1 11-02-2011 01:22 PM
How to change fonts on all buttons (Artist/MC Control) crustn Artist Series 2 09-22-2011 05:40 AM
> Can't change a Group's Color Howardk Pro Tools TDM Systems (Mac) 0 07-29-2009 10:00 AM
Change the color of the track hfd5 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-12-2008 08:59 AM
Change color of audio? neil conti 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-22-2001 12:14 PM
