Old 12-05-2024, 06:15 PM
greg.bob greg.bob is offline
Default No input
I know this is not as detailed as it should be. But I am going to try with the basics
Using Flock Patch
Apollo x16
Protool ultimate
Double RAVEN MXI 4 touch screen
Mac m2 running Sonoma
Switch craft foh patch bay
Mk s88n midi keyboard
Komplete 15 collector edition
All Mogami gold cables
Dangerousmusic hardware
Manley voxbox
Grace preamp
SPL gold mkii preamps
We are able to get sound from the demo song.
We cannot get input at all, mic or line nor sound from midi keyboard
Old 12-05-2024, 06:50 PM
Default Re: No input
Hi
Welcome to DUC.
The most common cause of this is not having microphone or any other audio input is not having macOS "Microphone" privileges granted to Pro Tools. Check this is enabled in
System Settings > Privacy & Security > Microphone
Pro Tools will seem to work fine but you just won't every get any audio input to the app, it has nothing to do with actual microphones, Apple means any audio input.
The other thing to check is that Pro Tools is starting up as whatever version you think it should, for example if it is only starting up as Pro Tools Intro you only have the first four audio inputs that will work, and Pro Tools frustratingly offers no clue or warning about that. (Lack of any warning like that when you exceed I/O limits in any versions of Pro Tools bugs the heck out of me... very user unfriendly behavior).
(Edit: You should also confirm in the Apollo Console that you have that input signal routed to the DAW input, it's not muted etc.).
MIDI keyboards don't produce any sound, you need to feed them through a virtual instrument plugin for that to happen, and I have no clue exactly what you are doing there. Focus on getting audio input working first.
Input setting help (hardware input 1 wants to be Protools input 5) TheBaron Pro Tools 2020 3 07-14-2020 09:14 AM
M-Audio Fast Track Ultra fisical input 1 appears in VST input 2 blackpauldays FireWire & USB Audio Interfaces (Win) 0 07-19-2016 08:43 AM
Issue Recording Vocals PT12/MBox Pro 3 Input 03 (rear panel) - Works with input 01 lnc77 Pro Tools 12 6 03-28-2016 01:18 AM
Post-roll stays on input (in Auto-input)?! Tim R. Pro Tools TDM Systems (Mac) 2 06-04-2009 12:02 PM
switch auto input and input only monitor with midiprotocol mmestudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-27-2003 03:51 PM
