Old 01-18-2022, 03:36 AM
oortone oortone is offline
Default Multi mono - Singal generator out of phase
ProTools Ultimate 21.10.67
Minimac (ca. 2018)
Can anyone else reproduce this bug:
  • Start blank
  • Add one audio channel and master out channel
  • Add some phase meter at master out
  • On the audio channel insert the built in "Signal Generator" as multi mono plug in
  • Twiddle the frequency
  • Somewhere you will find frequencies that are not 100% in phase L/R
If I close the project (but not necessarily ProTools) and re-open, the phenomenon goes away.
If I add a new track and repeat I get the same phenomenon, not necessarily on the same frequencies. It too goes away if I save and re-open.
Old 01-18-2022, 04:49 AM
midnightrambler midnightrambler is offline
Default Re: Multi mono - Singal generator out of phase
Why would you expect 2 different instances (because that's what multi-mono is) of a signal generator to stay in phase when you move frequencies? I'd be more amazed if they did stay 100% locked.
Old 01-18-2022, 05:26 AM
It's not two instances.
I believe Multi Mono is offered to deliver the opportunity to use a plugin that's not available in Stereo or Multichannel to the user. I'd therefore expect it to be in phase which it usually is as far as I know.
Why would the two channels not be in phase when instansiated together and presented in one single plugin window?
Old 01-18-2022, 06:58 AM
dominicperry dominicperry is offline
Because two different frequencies are, by definition, not in phase.
If you wander off a base frequency and then come back to the original frequency, there is no guarantee that the zero-crossing point will be at the same place. So that will then be out of phase with a separate instance that has never been changed.
Old 01-18-2022, 08:11 AM
Beyond what Dom is saying(which I tend to agree with), what's the end goal here? What are you trying to achieve(or is it just an experiment that isn't giving an expected result)?
In general terms, I don't think much time was spent creating the signal generator plugin and I would not count on it for critical purposes. Its handy for testing routing, dropping a 1KHz tone and such, but for critical work, I would lean on something else, like the Alan Parsons Sound Check CD or a hardware tone generator
Old 01-18-2022, 08:35 AM
Multi-mono instantiations of signal generator are not phase-locked. create a mono aux with a single instantiation of sig gen and bus to where it needs to go.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 01-26-2022, 04:43 AM
There're not multiple frequencies in a multi-mono instance of this plugin. There's one frequency - two channels.
Old 01-26-2022, 04:45 AM
That's interesting. Is this true for all Multi-Mono plugins; that phase coherency is not guaranteed? In that case I don't get what use Multi Mono is meant for.
Thanks for the tip on using an aux instead.
Old 01-26-2022, 04:49 AM
Actually, this was just something I discovered while trying to find an inconsistency in the analog part of my monitor system, so I used Signal Generator to generate different frequencies. Suddenly I saw the channels where out of phase and thought there was someting wrong with the amplifier.
I used a stereo channel just by accident, didn't think there would be a phase issue. In the case of Signal Generator there's no need for a stereochannel but if this phase issue exists in Trim (which is also only available as multi mono) then that's very bad.
Old 01-26-2022, 06:20 AM
The phase issue exists in the "generation" part, i.e. when you're sliding the frequency up and down even the tiniest amount of delay between the computer processing the left/right movement of the slider will knock the generator out of time (and therefore out of phase) ever so slightly. This isn't going to be an issue with "processing" - or at least you'd hope not, otherwise the whole system would fail, not just one multi-mono plugin.
Multi-mono Signal Generator TDM out of phase !!! mangoustine Pro Tools TDM Systems (Mac) 5 04-15-2019 04:53 AM
Signal generator TDM out of phase.... Kroger Pro Tools TDM Systems (Mac) 11 04-05-2009 12:50 PM
Phase coherency (multi-mono vs Multichannel) Ray Fabi Pro Tools TDM Systems (Mac) 0 01-21-2006 02:56 PM
Signal generator out of phase garret Pro Tools TDM Systems (Mac) 12 12-01-2005 10:19 AM
I Need Clarification. Difference between Multi Channel and Multi Mono Plugs citi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-13-2002 11:08 AM
