Re: VCA Meters Misaligned in PT 2021.10 on Big Sur
Oddly I have never seen this on 2021.10 and Big Sur 11.6.1. Now on 2021.12 and 11.6.2 and getting the weird meter screen drawing on VCAs and sends. Touching the send fader fixes them. resizing the track size (edit window) or toggling narrow mix window on/off fixes the VCA meters.
Not a show stopper but really annoying for something that I spend so much money on. Come on Avid!
offthewallproductions Mac Pro 5,1 3.46 Ghz 12 core, Open Core 0.9.8, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, macOS 12.7.4 Pro Tools Ultimate 2024.3.1/HD Driver 2023.3 HDX, UA Octo PCIe card in external TB3 chassis, MTRX Studio I/O, C|24 control surface. Genelec 1031AP/7070A 5.1 monitoring. |
same hereon m1 mac mini big sur.
It’s possible that prompting Pro Tools to re-draw the window layout boundaries may help snap the graphics back into place. I had some success correcting a similar GUI issue by resizing the misaligned window.
For me the misalignment primarily affected the edit window when switching between different window configurations. Just seems like 2021.12 doesn’t play nice with window config templates from past versions. Once I resized the misaligned windows and updated window configs, alignmenmt fell back into place. Not sure if this fix applies to all GUI missalignment issues but it’s worth a shot. I’m running Pro Tools 2021.12 with Big Sur 11.4 |
I'm having a similar problem when in the relink window. I first need to move the window around a bit to refresh it otherwise everything is a bit off. if I try to click on say, a drive, it selects another part of the window. Same happens when I switch back to my edit window. I need grab the menu bar on the edit window and move it a bit to refresh it.
This is on a 2019 MacBook Pro running Big Sur 11.6.2, PT Ultimate 2021.12.00 |
Ok so I have a solution
It seems to be some kind or GUI refresh glitch, that seems to be common with the import track problems if you slide a normally working track from let's say the left of the weird track to its right, everything goes back to normal. It works for imported tracks that go kind of blank on the console, but also for VCA tracks with misaligned meters. Bizarre problem, simple but weird solution
Mark Haliday France, Rochefort 17300 Mixing & Mastering, Writer, Teacher Pro Tools Ultimate & Carbon M2 Max Studio |
#16
Also having a similar issue on Big Sur 11.6.2. I'm not seeing misalignment, but for me, the meters just aren't loading at all when importing tracks or creating tracks from track presets. Rearranging the track fixes it. But it's still annoying.
www.HellfireBeats.com UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61 Pro Tools 2021.12 Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2 16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1 27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15 |
#17
Easy fix, annoying but works. Take any track that works normally in the console and move it past the problematic track(s) (left to right or right to left). This apparently forces a refresh of the Gui and the artifacts disappear. Glitches in the edit screen seem to vanish when zooming tracks with the +/- in the bottom right hand corner of the edit window
#18
Hey Everyone.
I am experiencing this as well. The PT tech support had never heard of it. That being said. I did notice it (after) I imported a template from and earlier version. There is a quick fix (all be it temporary). You can de-select the assigned subgroup, and re-assign it. Works like a charm. You will have to do it each time you open the session, but only takes a second. Cheers JT |
#19
I am so tired of this bug. Sure, there are easy workarounds, but with how many VCAs I use and how many sessions I go through every day, if this bug isn’t fixed in the next update, I will be extremely disappointed. It was painful waiting until December to not have it fixed. So if it becomes a lingering long time bug, I will be so frustrated.
The fact that you mention they weren’t aware of it is not promising.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course Pro Tools HDX 2023.9 Mac Pro 7,1 3.2 GHz 16-Core Xeon W 160 GB RAM macOS 11.7.4 Noisebox Studios -Utah Recording Studio |
#20
Do you experience the bug with new sessions created within the current version, or only with templates or sessions created in an older version? Sent from my iPhone using Tapatalk
Joe Tools Re-Recording Mixer/Sound Designer Nova Scotia Canada OS Ventura 13.0 Pro Tools Ultimate 2022.12 Mac Studio Max 32GB Ram OS 10.8.5 Pro Tools HD Accel Version 10.3.8 Mid 2012 Mac Pro 5,1 32GB Ram |
Misaligned labels on mixer | midnightrambler | Pro Tools | 1 | 01-25-2022 03:53 AM |
Edit Window Misaligned in PT 2021.7 on Big Sur and Monterey as attached photos | Melon | Pro Tools | 6 | 11-01-2021 08:05 PM |
Meters are all choppy in 2021.6 | paul_g | Pro Tools | 1 | 06-28-2021 07:34 AM |
Help! Audio misaligned bug. | nuhacikel | Pro Tools 2020 | 0 | 01-13-2021 01:25 PM |
Playhead misaligned? | Recengnr24 | Pro Tools HDX & HD Native Systems (Mac) | 1 | 11-04-2013 02:14 PM |
