Audio play back issue
I have been a user of Pro Tools 8 for a while now. Until recently, i have been having an issue with audio playback. I have no problems recording audio but when i began playback, i get an error message that reads "Audio device buffer underflowed. If this occurs frequently, try decreasing the H/W Buffer Size in the Playback Engine or remove other Firewire devices (-6085 or -6086)" Has anyone else had this problem and how did you fix it?
Re: Audio play back issue
-6085 and -6086 errors are typical of running Pro Tools with incompatible computer hardware and/or with incompatible hardware active while using Pro Tools, or possibly a hardware misconfiguration.
Without a complete report of your computer specs, we will not be able to help you other than with generic suggestions. (disable wireless network devices when using Pro Tools, etc) If you want detailed troubleshooting of your issue for your computer/pro tools system, you need to follow the instructions from the "Help us Help you - what you need to know before posting" thread. Those instructions are as follows: Quote:
Play back issue | brian_ | Getting Started | 4 | 03-04-2014 11:07 AM |
MIDI Issue when recording and play back in PT8 LE | musiclovin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 24 | 09-23-2009 07:14 AM |
Midi connection and play back issue | Travele611 | Pro Tools TDM Systems (Mac) | 0 | 11-21-2007 10:54 PM |
PLAY BACK ISSUE | John Rose | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-06-2006 07:55 PM |
play back and selection issue | PATofNAVAR | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-01-2005 06:59 PM |
