Avid Control Connection Problems
There are many posts with issues on Avid Control, and I've googled and tried most of them. Still limited luck.
My issue is specific to Avid Control. I also have an Artist Mix and Avid Dock, and both of them connect reliably. It's just the iPad app that has trouble. Incidentally it connects in 1 of 50 times, but not the rest. Which means it's not totally broken but something is just not computing in the setup. It's the latest version 21.10.1. I've checked that the firewall is open, and all the WiFi settings are appropriate. I can ping the workstation from my iPad. I have the same problem on two separate iPads, one an old iPad Mini 2, and one a more recent iPad Pro 12". iPad has been set to manual IP, etc. etc. I made sure Bonjour is installed and running (and the Artist & Dock) manage to use it to find it. Last night I uninstalled and re-installed EuControl software, and when it restarted Control connected. Then I had the system on sleep for the night and this morning I'm back to square 1. Control launches but doesn't connect and only shows the small warning triangle. Not really up for re-installing EuControl ever morning. I really wish there was a way of just entering the IP of where to connect to for EuControl than do this fragile auto discovery. I mean on an iPad app that would be dead simple. Any other ideas? This is a Windows 10Pro system, latest version of all the software and firmware. System runs a BitDefender firewall. I tried disabling to test without it, that didn't seem to help though. Super frustrating. Thanks, Jan |
Re: Avid Control Connection Problems
Two thoughts off the top of my head: Assign the tablet a static IP address. Don't sleep the system with Eucontrol running.
I tried the static IP, that didn't help. Not sleeping the system may be something to consider. Jan |
Sleep breaks the network connection and Bonjour. Sometimes restarting all EUCON Apps from the right click menu helps other times you have to restart the machine as Bonjour is broken(nothing to do with Avid). If you are familiar with Windows Services you can restart Bonjour Service instead of restating Windows.
I have the same problem, tho I on MacOS. Avid Control on my iPad has never been able to connect. More troubleshooting ideas?
In the end I abandoned the setup, it was getting too frustrating. Switched to a UF8 controller, which works quite nice.
Too late for you, but I run the Dock, iPad and Avid Control. I had some problems like yours initially, I had to make sure all of my computers were connecting to the same network and make sure that the computer and ipad had forgotten all other access points (otherwise they would search for others). For example, I have three different access points with a strong signal in my studio space. I had to manually make sure that the devices would forget them and not try to auto switch. You would think that assigning a static IP would prevent that, but it is possible that your networks were still mixed
After that, I never had any more problems. I did not assign static ip addresses. Just made sure that systems were not switching to other networks in the house.
Lenovo Legion 5 Laptop PC, Intel Hexa-Core i7-10750H, Nvidia GTX 1650Ti, 32GB DDR4 RAM, 512GB SSD, Windows 10 Enterprise (20H2), 1TB SSD external work drive, Focusrite Scarlett 18i20, Pro Tools 2022.9, Avid Control w/Apple iPad, Avid Dock Control Surface, Avid S1. |
Jan |
Most Waves plugins cannot be set properly from Avid control surfaces / Avid Control? | XJENSEN | Avid S1, S3, Dock and Control App | 3 | 08-11-2022 06:59 AM |
Avid Artist Control + Logic problems. | matthihat | Artist Series | 4 | 02-03-2019 12:37 AM |
Help Avid Artist Control losing connection with logic X using usb to ethernet adapter | smartinez5878 | Artist Series | 4 | 06-23-2014 11:10 PM |
Control Surface For Protools 10 Mackie Pro Control or Avid Artist Control | lberrios1962 | Pro Tools 10 | 18 | 05-26-2012 12:51 AM |
Artist Control / Ethernet Connection and Noise Problems | lberrios1962 | Artist Series | 8 | 05-04-2012 08:20 AM |
