Greetings,
Running Mac OS 11.5.1 on a 27" 2017 iMac i7. HDX isn't recognized since the Big Sur install without adding a line of Terminal code each time I restart, which is sudo kextload /Library/Extensions/DigiDal.kext per the Knowledge Base. Then functionality is restored. Will there be a patch soon that will remedy this? Thanks. |
Big Sur 11.6 addressed all of my kext issues, however, I do not run HDX, so cannot confirm for that.
Matt McKenzie-Smith mattrixx.net SourceConnect - mattrixx AVID Collab user - mattrixx MacStudio Ultra / LogicProX / IzotopeRX9+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFXII / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01 |
Having the same issue running HD Native TB, PT v2021.7.0 on OS 11.6.
I found this in another thread, which gives the terminal line you are using, but goes on to include a procedure to use if you're having to do it every time you start up: https://avid.secure.force.com/pkb/ar...__2&popup=true I was having the same problem getting Desktop Video to load, so I could run video out of my BMD UltraStudio. Spent hours trying different solutions I'd seen online for that . Ironically, going through the steps in the article above fixed the BMD issue immediately, but did NOT fix the Pro Tools issue! I still have to type in the terminal code every time I restart.
Chris Erlon |
![]() Quote:
Sounds like a permission problem. Repair permissions on your boot drive and try again.
![]() Quote:
Did a little researching and only thing relevant seemed to be too reseat the cables. Which I did...did not help. Nothing physical changed from Catalina to Big Sur...just software...so WTF is going on? |
![]() Quote:
I used your Terminal command and it worked great. sudo kextload /Library/Extensions/DigiDal.kext I used to have a command that automatically operated whenever I started up my Mac, but unfortunately I deleted it when cleaning up startup items. The link to the avid page no longer has this command. Any idea how to do this? I can't find it anywhere. Here is that link again. https://avid.secure.force.com/pkb/ar...__2&popup=true Steve |
PT 2020.12.0/MacOS Catalina and the HD Native/HDX Driver | jeff markham | Pro Tools 2020 | 4 | 02-23-2021 11:19 AM |
No sounds from HD Native after switching user accounts (macOS Sierra) | Focuret | Pro Tools HDX & HD Native Systems (Mac) | 8 | 12-12-2016 05:41 PM |
6.0 and Macos X | gmcgmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-11-2003 09:08 AM |
PT TDM 4.3.1 on G4-AGP w/MacOS 9.0.4? | Dzerdzinsky | Pro Tools TDM Systems (Mac) | 3 | 06-22-2000 12:40 AM |
MacOS 9.04 | midimac | Pro Tools TDM Systems (Mac) | 4 | 04-21-2000 05:55 AM |
