has anyone noticed that importing clip-groups has become extremely buggy in 10.2? Over here I can only import one clip-group at a time otherwise PT will return an error-message and will crash on the next attempt to save. Doing it one by one seems to work. AVID, can this be improved? It makes batch importing CGs VERY tedious. BTW: When importing a CG to a new track PT will always create those tracks at the very bottom of the session ignoring the currently selected track. Would be great if it created the new tracks below the selected one. Thanks, frank.
PTHDn 2022.12 (OSX12.6.2), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM, Xilica Neutrino, Meyersound Acheron |
so you're saying you'd like things to have less than a thousands bugs...?
www.kfaudio.ca |
I had a crash issue with clip-groups of many tracks (I think it was 27 tracks!). After exporting and importing it was fine, but then I wanted to remove this group from the clip list. When I did it, PT crashed on the next save.
The solution was to remove every single element (those that show if you click the arrow) one by one. Maybe it's related? PT 10.2 / 10.6.8
http://felixrost.de Last edited by Felix Rost; 08-14-2012 at 12:30 PM. Reason: typos |
Still the same problem in PT 10.3.4. First an error message pops up (see picture) then PT crashes. The only way around was to d&d one after the other from the finder to the clip list.
error message.png |
Region Groups-->Clip Groups Import File Menu Not working | minister | Pro Tools 11 | 0 | 01-06-2014 12:23 PM |
10.3.3 HD - clip groups on big session causing serious lagging! | mhiratzka | macOS | 1 | 01-23-2013 09:57 PM |
Clip gain on clip groups: bug or feature? | idris | Post - Surround - Video | 6 | 01-02-2013 11:48 PM |
clip groups question/problem? | capt kirk | Pro Tools 10 | 1 | 11-01-2012 03:36 PM |
Clip Gain Needs To Follow Groups | DougBull | Pro Tools 10 | 3 | 11-18-2011 04:46 AM |
