Old 11-19-2010, 08:55 AM
SixChurchStreet SixChurchStreet is offline
Default Randomize MIDI within boundaries of current velocities...
Is there a way in Pro Tools, to take a set of MIDI notes, and randomize their velocities by plus or minus a defined percentage or value?
Just to make sure it's clear... I only want to move the notes I select by say, + or -, by between 1-10 velocity points randomly. So the overall vibe is kept, but the copied and pasted regions aren't exactly the same.
The only thing I've found so far is randomizing by a given percentage, but that only lets me set a range and a percentage. What I described above would do right job.
Mac Pro 5,1 2.4GHz 8-Core 16GB RAM High Sierra | Focusrite Scarlett 6i6 Mk2 | Pro Tools 2020 | Studio One 4
Old 11-19-2010, 10:44 AM
Default Re: Randomize MIDI within boundaries of current velocities...
Event Operations>Change Velocity.
Aaron Mulqueen - 001 HD Native
Old 11-19-2010, 11:44 AM
Of course. I had gotten that far. But there are many different ways to do many different things to velocity in that dialog box.
I did find a way to do what I wanted to do, though it wasn't straightforward, it did what I needed it to do.
I did a combination of two things...
Under Options: "Add" is ticked off with a value of 1.
"Randomize" is checked off with a value of 3.
This slightly randomized everything while moving all velocities up a hair. I'd rather them not have moved at all from their mean velocity, but up 1 wasn't noticeable. Did the trick.
[IMG] code is Off
MIDI Editor: indicate clip boundaries? DAWgEAR Pro Tools 10 0 06-23-2013 09:12 AM
Constrain midi velocities on the fly? focusbob 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-02-2011 06:32 PM
Randomize Midi thin ice Pro Tools TDM Systems (Mac) 0 05-14-2008 06:40 AM
Midi Event Window will quantize but won't randomize richardp MIDI 2 02-21-2008 02:29 AM
how to change midi velocities before recording reemixx Tips & Tricks 8 03-07-2006 04:12 AM
