Old 11-08-1999, 02:59 AM
Viper Viper is offline
Default ERROR: C Generic Waves DSP::Read Exec
Sometimes when opening protoolssessions I get this errormessage...
Time out 3
TestISRBit (0)
nil
...or similiar ones, and then my only choice is to take a forced shut-down of the mac. Has anyone experienced the same problem? Is it a Waves 2.8 problem? Is it a bad DSP-card?
PowerMac 9600/350
PTIII PCI 4.3.1.
Old 11-08-1999, 03:40 AM
Fokke van Saane Fokke van Saane is offline
Default Re: ERROR: C Generic Waves DSP::Read Exec
Do you have a Mackie HUI? waves 2.8 is not HUI compatible.
Old 11-08-1999, 03:53 AM
Mikey MTC Mikey MTC is offline
Waves 2.8 is absolutely HUI compatible.
Where did you hear otherwise?
Old 11-08-1999, 06:14 AM
I´m not using HUI.
Though, after restarting the mac, usually I can open the session without problems.
Old 11-08-1999, 10:19 AM
Compression Records Compression Records is offline
I understand that sessions saved under Waves 2.7 are sometimes corrupted. In my experience, a successful workaround is transferring all tracks (except one or two that you can recreate easily from scratch) from the corrupted session into a new empty session. Then recreate that track or two you didn't transfer.
Marco Marinangeli
Magelic Productions, Inc.
Compression Records
http://www.compressionrecords.com
Marco Marinangeli
Compression Records
Old 11-08-1999, 06:07 PM
Ray Lyon Ray Lyon is offline
Similar problems exist with opening files that formerly used WS 2.6. (I never upgraded to 2.7) Usually, it occurs after I open a file after closing a previous one. The only solution I know of is to quit PT, and restart the program. If that doesn't work restart the Mac.
Old 11-09-1999, 01:01 AM
Pede Pede is offline
Viper,
i don't think that this has anything to do with older waves or with Hui. I experienced the same messages while opening a session but
also while opening a waves plug in a session with totally new sessions created with 4.3.2 and waves 2.8.
I don't know where it comes from but would be
interested too.Working with 2x D24 and 4 DSP Farms on a 9600/300.
Old 11-09-1999, 05:24 AM
AdamFrick AdamFrick is offline
I experienced the same error on a session created on PT4.3.1, Waves 2.8, DAE 3.4.2f9 - it is fine 99.9% of the time, but once (when I had the composer sitting right here, of course) I got that error (it mentioned something about onyx...) and had to reboot eventually. bwg3, mixplus, bit3chassis, etc
-adam
Old 11-09-1999, 07:09 AM
imported_yes imported_yes is offline
I would suggest a clean install of the Waves folder. Pull your old folder onto your desktop. Trash the DAE & Waves Prefs and Empty the trash. Run the installer. Restart.You should be fine after that. Make sure you allocate enough memory to the DAE.
yes
Old 11-09-1999, 11:31 AM
Mikey,
Do you own a HUI?
I've had a long conversation together with Jacek Galowski with Waves and Waves finally admitted that problems exist and will be solved in a next update.
Try PAZ or L1 and change views a lot of times. Suddenly it will crash. When i disable the HUI it works fine. WS 2.6 is ok, HUI-wise.
WAVES plugin users, please read... planetkyle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 05-22-2016 09:41 AM
EXEC file - PLEASE HELP! Vulfie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 10-06-2008 12:35 PM
EXEC file - PLEASE HELP! Vulfie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-19-2007 02:56 AM
cant read exec files from plugins on my mac cesarcortes 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-04-2007 08:05 PM
Can't open session-generic grey "exec" icon gman007 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-25-2005 10:28 AM
