For some reason when I hit stop on the transport, I see a huge spike in my CPU while using Avenger. It shoots up to close to 300% and then comes back down. There doesn't even have to be any midi info going to it. It seems to be the "all notes off" command that's making it happen (although I'm not totally sure). I see the spike both on the CPU% window within Avenger and the System Usage window. This even happens if I make a test session with only an Avenger track and no midi even going to it. This happens no matter what playback engine I select. I don't see this same behavior in Logic Pro. The only way I can use Avenger is to set my buffer size to 512 or even 1024. Is there some setting that I'm missing or should check?
Thank you for any advice. 2023 Mac Studio 64 GB memory Sonoma 14.5 Pro Tools Ultimate 2024.6.0 Avenger v2.1.1 (AAX) |
![]() Quote:
- Mac Studio M2 Ultra/OS 14.5/64gb/2TB/UA Apollo x3 + OctoPre x3 + UA Satellite x3/PT 2024.6/ Logic 11.01/Reason 13 - MSI GT77/13980HX/W11 Pro 23H2/64GB/4TB/Arturia Minifuse 2/Tuned for low DPC/PT 2024.6/Reason 13 |
![]() Quote:
Ahh I haven't updated for months. Thanks for the heads up, will launch the vengeance updater right now. Awesome!
In many case (if not most), issues like this can be pinpointed down to a plugin needing an update. It's a good general rule to start your quest -- any "strange issue" quest -- by checking for updates to the software causing that particular problem.
Better yet, download MacUpdater and let it keep you updated. It's one of the best apps I've obtained over the past couple years. I start each day at the studio by pouring coffee, grabbing a bite to eat, then double-clicking that MacUpdater icon. |
![]() Quote:
Will check it out, cheers ![]()
VPS-Avenger - Pro Tools timed out trying to stop | Robert U | Virtual Instruments | 0 | 05-09-2024 12:41 PM |
VPS Avenger and automation | itsjustmeee123 | Virtual Instruments | 6 | 04-09-2023 09:34 AM |
Avenger changes copy protection | musicman691 | AAX Plug-ins | 0 | 08-26-2019 06:31 PM |
Parawave Rapid VI - Is this the Avenger Competition? | DonaldM | Virtual Instruments | 3 | 09-28-2018 06:34 AM |
