Eucon S3, Dock and Avid Control dropping out
I recently purchased a Mac Mini M1 2020 as an interim computer (Waiting for the Max or Pro version) as my Trashcan's GPU's have died. Pro Tools seems to run OK on it but I'm getting constant drop outs on my S3, Dock and Avid Control app. EUCON doesn't seem to be very happy and I can't get to the bottom of it. I have tried different ethernet cables (I'm using a switch) and I've assigned static IP's for all 3. My computer only has 8GB of memory so I'm thinking it may be that (?).
A few times EUCON has displayed a 'Duplicate surface unit addresses detected' message which makes no sense as I don't have more than one S3 and I have assigned it's own IP address. I've tried switching off each surface but the problem persists. Any ideas out there? |
Re: Eucon S3, Dock and Avid Control dropping out
Which OS are you running?
Hi albee1952. I'm running macOS 11.6 Big Sur
Set Up
Mac Mini M1 2020 8GB l MacOS 11.6 Big Sur UAD Apollo 8 AVID S3 & Pro Tools Dock Pro Tools Ultimate 2021.12.0 EuControl 2021.10.1.29 TP Link TL-SG1016 1Gbit switch
Mac Studio Max 32GB - macOS Monterey 12.4 - Pro Tools Ultimate 2022.5.0 - UAD Apollo 8 - Avid S3 - Avid Pro Tools Dock |
If that's the case switch the controllers to DHCP or make sure your fixed addresses are outside the range of what the DHCP server hands out. If the above is not the case maybe post the IPs that you're using so it's easier to narrow down the issue?
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
I've narrowed it down to the S3. I switched it off and just used the Dock and Avid control and no drop outs. I unplugged my computer from the network and plugged the S3 directly into the computer and it dropped out within 30secs. For some reason my S3 just doesn't like this computer. It has run smoothly with my Trashcan for years. Could it be a Firmware glitch? Something to do with Apple siliconM1/Rosetta 2. Next step will be to test it on another computer I suppose.
Its not firmware as this hasn't changed in ages. It could be power supply related. Definitely try it on another system first. I presume its all uptodate on 21.10.1 ?
SOLVED: The problem was the layouts saved in my template (I think). They somehow got corrupted. I made a new template and imported all the tracks from my current project and the problem disappeared. I normally have 4 different layouts which get saved somewhere in the session data (Can you access these files?).
Could have been something else in the session as well. Thanks for the input.
Avid Dock - Protool 2018.12 - Eucon Firmware compatibility | lof_audio | Pro Tools 2018 | 0 | 09-08-2021 05:19 PM |
Ex MC Control/Artist Control users and now AVID Dock User. Questions | Zak7 | Avid S1, S3, Dock and Control App | 8 | 03-11-2021 11:30 AM |
Any issues/improvement with Eucon 20.5.0 and Logic Pro X 10.5 (S1, Dock, Control)? | sjgam | Avid S1, S3, Dock and Control App | 2 | 06-19-2020 04:43 AM |
Eucon/S3/Dock/Avid Control delay in responding | feakerboo | Avid S1, S3, Dock and Control App | 1 | 04-23-2020 06:43 PM |
Dock Monitor control 2018.7 eucon master fader | Jamie Mac | Avid S1, S3, Dock and Control App | 5 | 08-02-2018 07:31 PM |
