PTLE says can\'t find PDFreference guide in HELP menu
PTLE says can't find PDFreference guide in HELP menu
Any Help? Thanks
eddy |
Re: PTLE says can\'t find PDFreference guide in HELP menu
Hi Ed,
This is a common error if you dont have adobe installed, its in the utils directory on your os cd. Hope this helps, Aj
A Gentleman is one who can play the bagpipes, yet chooses not to. |
If you do have Acrobat and you still can't access it from the Pro Tools Help menu, then you probably need to do the following...
Make sure it is named exactly like this: "PT Reference Guide.pdf" and rename it if necessary. Pro Tools should have already installed it in the correct location on your hard drive: Digidesign -> Pro Tools -> Release Notes & Documentation -> PT Reference Guide.pdf The documents we put up on the website are named as close to the original as possible, but they have _ underscores instead of spaces for downloading and link management. We also may change the name in other ways to differentiate the version number or the translated language. So if you download an updated or translated version of your original document, you may want to use the same name and location of the original so that it will show up in the Help menu.
Administrator Avid Pro Audio Community |
Thanks guys
I solved the problem Thanks again Living la vida loca
eddy |
Reference Guide and other HELP MENU items. | ISLANDER | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-23-2011 04:18 PM |
Pro Tools Reference Guide Grayed Out in Help Menu | npratt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-25-2008 06:35 PM |
reference guide in pt documentation, not in pt help menu? | tonegiver | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-24-2007 04:00 PM |
Help menu/PT Reference Guide greyed out in 7.2?? | beggehorn | Pro Tools TDM Systems (Win) | 6 | 11-18-2006 09:58 PM |
Getting the Reference Guide back in the Help menu | RandB | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-03-2006 09:50 PM |
