Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Win)
Old 05-21-2013, 12:11 PM
qipi qipi is offline
Default Connecting external preamp to the mbox pro 3
Hi, I wish to connect the "Pro MPA-II" preamp to the Mbox pro
How do I do that - bypassing the built-in preamps?
I understood that it should be through the line-in? if so, how should I
make all the connections?
Thank you!
Old 05-21-2013, 05:34 PM
guatamas guatamas is offline
Default Re: Connecting external preamp to the mbox pro 3
The way I have my setup is through a patchbay, if I want to use my Pro VLA II, I send the signal, say a stereo drum bus track to the outputs of 5-6 or if its a mono track just 1 output (outs 1-4 are for my monitors) of the mbox pro (in the control panel the faders are up for outs 5-6) to the inputs of the VLA, adjust settings and take the outputs of the VLA back to the line inputs of the mbox. Of coarse all of this is done through a patchbay where all of the I/O are connected through the back of the patchbay and I just patch through the front. But this can be compared to what you want to do, when using line level devices always use line inputs because there is a risk of damaging the preamps of the mbox. The point of mic/DI is to bring those singnals up to line level, your MPA does this, that is a purpose of a preamp.
So what do you want to do? Use the MPA while tracking a vocal or instrument?
You'll need 2 TRS or XLR cables to do this or just 1 if your only tracking a mono source:
1 (or 2) output(s) of the MPA to line inputs of the mbox, connect the mic/DI to your MPA, adjust the settings, adjust Master volume so you don't clip going into Pro Tools and engage the buttons on the front of the mbox to receive line in. In pro tools select the right inputs of the mbox and just hit record
If you want to use the MPA or another signal processor as an insert (like a plugin) this requires a slightly different cabling setup
Old 05-21-2013, 06:37 PM
Feed the ART unit into the LINE inputs(3 and 4). Do NOT patch the preamp to the XLR inputs as they are MIC level(and the preamp is sending LINE level). Balanced cables are best.
Gigabyte X79/intel i7 3930K, 32GB RAM, Presonus Studio 1810C
I started in this business with nothing..........and I have most of it left
Old 05-21-2013, 06:43 PM
Bill Denton Bill Denton is offline
Sorry, guatamas...but do you really think somebody who does not yet know how to connect a preamp needs to get involved with patchbays and such? I know you meant well, but it's best to match the advice to the audience...
Now...to the OP...here's how you do it...
Obtain two cables with 1/4" TRS (tip/ring/sleeve) connectors on both ends. These are called balanced cables, and the connectors shoule look like the 1/4" connector on a pair of stereo headphones. The cables should each be long enough to reach from the Pro MPA-II to the Mbox Pro.
On the rear of the Pro MPA-II, plug one end of each cable into each of the 1/4" balanced outputs (one cable plugged into Channel 1, the other cable plugged into Channel 2).
Locate the cable that is connected to Channel 1 on the Pro MPA-II and plug the other end into Line Input 3 on your Mbox Pro.
Locate the cable that is connected to Channel 2 on the Pro MPA-II and plug the other end into Line Input 4 on your Mbox Pro.
(By convention, odd numbered inputs/outputs are used for the left stereo channel, even numbered inputs/outputs are used for the right stereo channel.)
Ensure that the +4/-10 switch adjacent to Line Inputs 3 & 4 on your Mbox Pro is in the out position, for +4 dBu.
You will not be adjusting any "input levels" on the Mbox Pro, you will make all adjustments on the Pro MPA-II.
The manual for the Pro MPA-II contains very good instructions for its operation...I recommend you read and follow them.
When recording in Pro Tools (or any other DAW), you will want to adjust the Output Level and/or the Master Output Level control(s) on the Pro MPA-II so the level meter on the audio track you are recording reads an average of around -18 DBFS.
Good luck...
X
Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...)
Just rockin'...what more is there?
Bill in Pittsburgh
Old 05-21-2013, 06:50 PM
Don't use XLR, that's my mistake. Use TRS instead
Old 05-21-2013, 08:08 PM
nst7 nst7 is offline
One important thing, after you've done what Bill said - Make sure that the "mic/line button on the front of the unit is pressed IN, for Line.
Old 05-21-2013, 11:25 PM
Default Thank you all!!!
You really covered it all up.
I am not used to this kind of detailed answers :)
10X!!!
Connecting external preamp Maddern macOS 4 12-23-2012 08:08 AM
Mbox 2 pro and external preamp?? trustlove 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-12-2010 11:22 AM
Mbox 2 pro and external preamp?? trustlove 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-12-2010 09:38 AM
Trouble Connecting Preamp to Mbox 2 Mini Big C Dub 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 11-02-2009 11:22 AM
Connecting and Setting up and external preamp lew742man 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 01-17-2008 09:10 AM
