how to change speed and bounce !!!
hi,
If i need to speed up a session little bit I use protools sync to change the speed , but when i bounce, the effect of changing speed gone!! is there any way to speed up a session an bounce it with speed I want??? |
Re: how to change speed and bounce !!!
re-record the mix back into protools to a new record track in realtime using an internal buss.
cheers geo
georgia hilton CAS MPSE MPE Hilton Media Management Film Doctors http://www.filmdoctors.com Me... http://georgiahilton.webs.com/ Stage 32 http://www.stage32.com/profile/6569/georgia-hilton My Production Company http://www.hiltonmm.com CREDITS (partial) http://www.imdb.com/name/nm0385255/resume MEMBER: IATSE LOCAL 700 |
You should not be messing with the clocking source to change the speed of a session!! this is something that should be done in the post mix stage. do your mix at the normal speed then import it into a new session and use one of the audiosuite plugins to change the speed... X-form, Pitch n time, Speed etc. or just use the Digi default time stretch. Chris
and btw.. what I told you is wrong. You'd be adding twice the speed change. You need to track to an external device so have the speed differential only once, or do what chris mentions, modify the speed on a normally re-recorded file.
cheers geo sorry.
Pro Tools speed change after bounce?? | iamdano | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 11-15-2010 10:13 PM |
Plug-in for speed change? | jjsoundoc | Post - Surround - Video | 9 | 06-01-2009 08:59 AM |
how can I "speed up" without pitch change? | BubbaHoTep | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 01-07-2006 12:11 PM |
Change speed and pitch? | likegluelikecrew | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-13-2004 09:37 AM |
Change speed | secutanudu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-18-2002 04:59 AM |
