recording midi and audio data how?!
ive got a question.
i recorded guitar in an audio track and then i made a midi track. now if i say it shall bounce the thingy then all i get is the audio file.... how can i get the midi arrengement AND the audio file into one .wav file??? can some body help me pls?? |
Re: recording midi and audio data how?!
the really strange thing is...
i got the digi001 interface and when i record audio files then i hear it thru the interface headphones...but i dont hear the midi notes...i only hear the midi notes thru the normal PC monitors... =O/ |
how do you monitor your midi gear?hardware or soft?
When you bounce, protools only bounces the output pair you decide.1-2,3-4 etc. To be able to bounce the midi instrument with audio,your midi units output should go to the inputs of your digi system and you should assign it to the same out as your audio. Oz |
You don't even need to record the MIDI tracks to audio, you can just bus them into aux inputs.
Dual 2.3 GHz PowerPC G5 2.5GB RAM OS 10.4.6 HD 2 Accel PT 7.1cs9 192 I/O |
Hello:
Ok whats happening is your hearing the midi being played from your soundcard / synth , but your not routing it into protools. I agree with Oz but would like to add that you can record your midi tracks to audio, and then include them in your bounce. Take your soundcard / synth outputs and run them into 3-4 in, for example. Setup a stereo track and record your midi tracks. Now you can add effects ect to the new audio tracks you've created. Hope that helps. Rob. |
Recording MIDI data into Audio (external synth) | typhy | macOS | 1 | 11-04-2011 06:49 AM |
Recording Midi Data to Audio | andrewkstone | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-22-2010 10:14 PM |
Problem with recording MIDI data | Fladlien | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-10-2005 06:04 AM |
recording midi clock data on P/T Mix | jer | Tips & Tricks | 0 | 03-31-2004 02:43 PM |
recording midi data | JPMenz | MIDI | 1 | 04-04-2002 04:53 PM |
