Help - Reverb
I can not put any reverb on to my vocal track which is not extremely unnoticable.
Are there any default settings? or can anybody tell me a subtle setting for a vocal track. Every time I use this plug in I can hear it very working very loudly and it makes it sound like my vocal is in a very large hall and it buries it into the background. The only thing I can do to reduce the effect is to lower the mix but that is the same settings on a lower volume which is no good. Are there any other free reverb plug in's which are better?. Any help would be great Thanks. |
Re: Help - Reverb
Consider creating an Aux track. Place reverb on that track to desired settings. Then, on your vox tracks, use an Aux Send to send some of your vocal to the Aux Input track for the reverb. Mix as little or as much as you like. This will keep your main vox dry and up in the mix and you can use the Aux Reverb track to give the mix your desired amount of "wet" signal.
*~*~*~*~*~*~*~*~*~*~*~*~*~*~*~*~*~* -Mac Pro -10GB Ram -Digi002 -ProTools 9 -OS 10.5.x |
Re: Help - Reverb
An addition to that thought - make sure your reverb on the aux track is set to 100% wet, otherwise you'll get some funky phasing issues. You can adjust wet/dry by lowering/raising the vox track vs. the aux reverb track.
003 Rack | Dell Studio XPS 8700 (Core i7 4790, 16GB RAM) | Windows 10 64-bit / PT 12.6 |
Re: Help - Reverb
So that means if I set up reverb as aux (which I alsmost always do) I shouldn't use the reverb plug-in to mix the signal - just set it to 100% & mix via aux fader with the dry signal? You learn something new every day!
My music Hardware 21.5" iMac 2.5GHz i5 24Gb (mid 2011), 003 rack, Roland TD12KV, Command8, Axiom 61, Maxtor OneTouch4 FW/750Gb/16Mb/7200rpm (audio/session drive) WD 1TB MyBook Studio (backup) Software OSX 10.13.6, PT2018.12.0 |
Re: Help - Reverb
Re: Help - Reverb
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
Re: Help - Reverb
Thx for the tip... I suppose it makes sense when I think about it!
Re: Help - Reverb
mike1234, it also sounds like maybe the reverb presets you're choosing are a little too "large", maybe try going for a smaller room emulation that way you'll be able to have a little more reverb in there without the vocals sounding a long way away.
If you're in to messing with the finer settings yourself, try: reducing the length of the tail a little using a pre-delay setting of 20-50ms if there isn't one already using a low pass filter to darken the reverb up a touch
Macbook Pro 2.4 GHz, OSX 10.5.5, PTLE 8 + MPT, 003R Factory, Apogee Mini-Me |
Flux ircam reverb and session reverb | klaukholm | Buy & Sell | 7 | 10-23-2013 12:42 PM |
Which Reverb? | TMDmedia | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 04-09-2007 12:24 PM |
About to sell PCM91 in favuor of Ren Reverb-Reverb One - is this a mistake? | hokuspocus | Pro Tools TDM Systems (Mac) | 14 | 04-15-2002 02:07 PM |
Reverb One - Vocal Reverb advice | ianmiller | Tips & Tricks | 2 | 10-28-2001 05:16 PM |
About DIGI now Reverb "Reverb one" | MAri | Pro Tools TDM Systems (Mac) | 1 | 07-25-2000 03:30 PM |
