Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 04-26-2021, 01:18 AM
EWF EWF is offline
Default Export clips as audio file (or undo without undoing copying to clipboard)
I just spent an hour editing an unintelligable section of a podcast into something quite easy to understand. Problem is I managed to shift a track out of sync in the process!
I want to select the clips I edited (on one track), export them as a new single file, the 'undo' to the point I made the error. I could then insert the exported clips instead of having to start from scratch.
Is this possible? I can't seem to find the way to do it. Export selected seems to just export the audio files associated with the clips.
Is there another way?
Cheers.
Protools 2020.12.0
Mac OS 11.2.3
Old 04-26-2021, 01:52 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Export clips as audio file (or undo without undoing copying to clipboard)
Consolidate
Janne
Old 04-26-2021, 04:34 AM
Sardi Sardi is offline
Rather than export it, just highlight the section you want to keep, paste it somewhere down the timeline away from everything else, consolidate it or group the clips and then insert where you need to.
Naming of clips when audio file ends with a number John Link macOS 5 06-02-2013 04:36 PM
UNDO: Why do i have multiple "Change Control value" before undoing what i need? EDurney macOS 5 01-10-2012 08:55 PM
Export markers to audio file jamiecer Pro Tools TDM Systems (Mac) 4 10-13-2009 09:25 AM
How to export audio beyond 2GB file limit? Beun 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 18 07-17-2007 07:45 AM
Need a solution for a stubborn Audio file ... copying from CD to my drive Roy Howell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 25 06-19-2003 12:38 AM
