should i turn off updating index message
Mac OS 9.0.4 has a schedule for updating its index.. will it harm my system at all if i turn it off ??? It's really annoying...where do i turn it off ??? THanks
Re: should i turn off updating index message
It will not harm your system to turn it off.
It is simply used by Sherlock to make the searching of files faster. (supposedly) 1. Open Sherlock. 2. Under 'Find' menu select 'Index Volumes' 3. Uncheck 'Use Schedule' next to every Hard Drive. 4. Quit Sherlock I agree with you. It is a pain in the neck. I allowed it to do a full index of my drives once, and then switched it off. It might be worth doing periodically, but it is not a good thing to be going on while you are running a ProTools session. Tweakhead. |
Actually, it doesn't make searching faster, but it does allow you to search for text "within" a document .
Funny thing is, there used to be an app that did this years ago for the mac, I just forget what it is - and you didn't have to index your HD to use it. Of course, it took a while... You should make sure there is no schedule for indexing. Of if there is, have it done when you don't work (for sure). DC |
11 can't index files with a slash | froyo | Pro Tools 11 | 5 | 01-22-2014 12:02 AM |
can I index for a mix CD on one track??? | djdamian | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-16-2008 05:24 PM |
error message after updating to cs10 | mal777 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-24-2006 02:43 AM |
CD index numbers | lambdapro | Pro Tools M-Powered (Win) | 5 | 05-23-2006 10:49 AM |
re index drives in 7.1 | x9blade | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-28-2006 05:05 PM |
